NX Digital Cluster / Z32 300ZX Brake Conversion w/2+2 cables / Z32 Rear 5 Lug Hubs
I'm located in Rancho Cucamonga/Fontana 91730 Area code, I can ship if needed.
All parts were working when removed but as is. No trades needed, Thanks for looking! 300ZX Ebrake Conversion $190 shipped with 2+2 cables BOLT ON for s13! $145 shipped with cut cables Includes all hardware and anchor bolts, springs, nuts, etc. Pads have good meat on them, sold with 2+2 cables for bolt on install Z32 Rear 5 Lug Hubs - $110 shipped -Bolt in 5 lug for S13/S14 -No play in bearings Z32 Rear 5 Lug Hubs Tabbed Type - $110 shipped -Bolt in 5 lug for S13/S14 -No play in bearings NX Digital Cluster with S13 Conversion Harness - $300 -Plug and play harness for any SR or Dual Cam S13! -Uses a s13 speed sensor and SR/Dual KA Cam temp sensor -All wires soldered/shrinktubed -Pick up prefered Last edited by surly; 09-23-2015 at 11:31 PM.. |
The cluster just uses the factory SR/KA water temp and speed sensors, not included but chances are your using one of those motors in your car.
