Overfenders bowed on one side
Put a set of overfenders on my s13, did some measuring for fitment and realized the one fender is sticking out an additional 6mm than the other.
Think running a wheel spacer on the one side will have any adverse affects? |
6mm isn't much. Fiberglass? I had to heat my 70mm widebody it was warped in to 48mm now its at 75mm. Don't run spacer on only one side. Changes ur scrub radious ( tracking line of your car) I imagine rack wouldn't like it over time. Or if doing to rear if you run 2way keep both sides same. Well really with any diff In my opinion. Heat ur fender edge and work it back 6mm or slot each mount hole and adjust it back in.
Nah ur good still. Leave all top.rievts in and just adjust the bottom/sides sucking the fender closer to tire. Don't fiberglass it. Or u can heat it and work it.back in slowly don't heat it to hot or ull wreck paint . As if u were rolling stock painted fenders without wrecking paint. Patience and not to close on heat
#6 | |
![]() Join Date: Aug 2011
Please don't work on cars anymore. We all may be young and dumb, but you need to learn the basics about cars first before doing something like this. |
The wheel spacer idea seemed like the easiest fix, but I didn't think it was the best fix. I asked a forum for advice and get a comment that adds nothing to the conversation. |
#8 | |
Sources of mechanical knowledge. -Your parents -Make friends locally via meets to show you directly. -Take your car to a friendly shop that show you how to consult & repair your work. -Go to community college for auto mechanic classes -Do self study and read books or documents on what works and what doesn't work. Don't bother asking questions on forums, we're not an internet index. |
#10 | |
What he meant to say, in a decent human, helpful way, is that is unsafe. do the fiberglass reforming, as mentioned earlier.
NAVY |
