SR20 in need of serious help....
Hey guys!
New to your group, and decided to join since I recently bought a Silvia and have barely any experience with SR's but have some basic knowledge with motors. About a week after I bought my Silvia, it started to leak a fair amount at boost. Mostly from one side. I thought maybe it was VAlve cover gasket but no dice. The car still ran great! Hauled like it did when I first got it! But when Idling smoked white pretty heavily. I am in the middle of completely ripping the motor down to the bare bones. I'm hoping it's just a headgasket? Comp test read 3 at 130psi and 1 at 60psi. I really hope it's not piston rings. I'll get to the gasket this long weekend to take a look. Any thoughts would be great and much appreciated!!! Secondly, if piston rings, I'll upgrade to forged parts. Which brands? What else should i do if I'm going to get into rebuilding the motor and what can I possibly skip? I don't want to cheap out but I am no where near mr.money bags! Thanks in advance guys!! Motor specs Red top SR. 740cc injectors Stock internals Gt2860rs with modded 86mm comp wheel Arp studs |
Depends what your budget is, really. I just spent over $4k fully building mine. that included:
forged pistons darton sleeves rods all bearings all studs all machine work valves springs retainers Tomei solid head setup with Tomei 270 cams probably some other stuff that im forgetting |
Sweet Jesus, 4 K hey... Wow I hope it doesn't cost me that much I was hoping like 2500 max 3000. Did you do any of the work yourself ? Besides the machining part obviously.
| gt2860rs, nissan, redtop, s13, silvia |
