Old 05-15-2009, 03:28 PM   #1
army240
army240's Avatar
army240 is an unknown quantity at this point
External Wastegate open at idle
Well, I finally started my engine, everything is fine, except one thing.
The wastegate is leaking exhaust gas! It's a Tial 44mm with a 12 psi spring I tried many vacuum line setup(Before throttle plate, after throttle plate, on the hot pipe, with the boost controler hooked, without the boost controler, with the top port open to the air, with the top port connected to the boost controler) and it still leak some exhaust gas! The dump tube is connected to the air, and it's annoying!
I tried to put some air pressure to the bottom port(like 15psi) to make it work, and the diaphragm is ok. I can hear the valve open and close. I applied some air pressure to the top port(to force it to be close) and it still leaking...
Any idea what I could do? I'm out of idea, lol!
Thanks a lot,
Frank
army240 is offline   Reply With Quote
Old 05-15-2009, 04:21 PM   #2
duffman1278
duffman1278's Avatar
duffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really niceduffman1278 is just really nice
Send a message via AIM to duffman1278
The wastegate is suppose to be open at idle, thats one of its purposes. It's suppose to release some of the exhaust pressure during certain phases so that you're not over working your turbo.
duffman1278 is offline   Reply With Quote
Old 05-16-2009, 12:47 AM   #3
Sileighty_85
Sileighty_85's Avatar
What???
Ive never heard of an External W/G opening at idle...
its on a 12lbs spring too. I dont know his setup but i dont think he making 12psi at idle
almost sounds like the spring is broken or maybe the valve is not seating correctly?
if you pull it off the Vac source does it still leak??
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-16-2009, 01:39 AM   #4
army240
army240's Avatar
Yes it does leak even if I disconnect all the vacuum line, and no, a wastegate should not be open at idle!
I'll try my friend Synapse wastegate to see if it does the same, and if not, i'm gonna check the spring in it. I believe the spring is correct, because when I blow some air from an air gun, I can hear the valve open and close when I let the air go out of the wastegate. After that, I'll ask Tial to change my wastegate, it was brand new! N/S on issue happens sometime I believe!
Thanks a lot for you advice,
Frank
Old 05-16-2009, 05:56 AM   #5
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
The valve stem could be coming in contact with the guide wall and catching/staying open... it happens with ssautochrome wastegates. The spring could also be wrong type or too short. Take the damn thing off and figure it out yourself by taking it apart
SR20 & RB20/25/26 in s13/s14 Wiring from $125 to $200.. Best prices EVER.
opponheimer is offline   Reply With Quote
Old 05-16-2009, 11:15 AM   #6
SR20JK
SR20JK is an unknown quantity at this point
please dont spread wrong information.
SR20JK is offline   Reply With Quote
Old 05-16-2009, 03:03 PM   #7
orion::S14
orion::S14's Avatar
orion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to beholdorion::S14 is a splendid one to behold
Are you missing the 'seat'...
If the valve moves freely, chances are...it's not sealing. It doesn't seal if it's missing the seat-->
Goes here:
???? - Brian
www.KA24DEvelopment.com
orion::S14 is offline   Reply With Quote
Old 05-16-2009, 09:11 PM   #8
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
i concur with orion
beat me to it
Dave
you also may have a piece of weld or debri caught in it and keeping the valve from closing all the way. best thing to do is take it off and examine
RB25 280z GT30/76R 441hp/381tq [email protected]
Z U L8R is offline   Reply With Quote
Old 05-16-2009, 10:49 PM   #9
army240
army240's Avatar
Ok thanks a lot guys! I found the problem, there was a dent in the valve seat! I really don't know how it as been damage... I replaced it, everything is fine!
Frank
