Ive just got a LSD
Ive just got a new LSD but it has the 5 bolt shafts and my s14 has the 6 bolt shafts and i was wondering who knew how to swap them out and how hard it is?
Should've payed attention to the details before ordering/buying a differential with different axle stubs.
Is you old differential an LSD? What differential did you purchase?
My SR20VET |
You need the 5bolt axles for that diff to work. Swapping axle stubs does nothing for you.
My SR20VET |
Not to mention different lengths. You cannot swap your open diff stubs into the R33 or vice versa. This is why I said you should've done your research before purchasing a part for your car.
My SR20VET |
