#32 |
I bet your swap didnt come with an ignitor, this thing. http://i85.photobucket.com/albums/k6...ou/ignitor.jpg And i can pretty much guarantee that you will put the CAS back in wrong, follow this guide and please dont fuck up your car.http://www.frsport.com/How-To-Set-Cr...gine_t_25.html
#34 |
i tried a couple minutes ago to see if i can get any codes off the ecu, because i just learned how to do so (screw the thing clockwise den counter clock wise)
i did this n everything in electronic just went crazy!!! the fuel pump sounded like it pumping alot, the automatic seatbelt was stuttering, and the ecu looking box between the 2 seats started clicking a lot ![]() wut the heck did i do :/ im afraid to touch the damn thing lol |
#36 | |
![]() Join Date: Dec 2009
#37 |
![]() Join Date: Feb 2009
i'm sorry but if u need this much help u should really go to a garage. everything that u r saying is something that someone with experience can help u with. doesn't matter about what motor it is. and u should really not be trouble shooting if u don't know how to check spark. that's something that most newbs know. i know that u r just starting out but do ur research before tackling a problem like this. and i'm not trying to hate on u just giving it to u how it is.
#38 |
I agree ^^ theres no shame in it especially if you're just starting out. THats how you learn is by others showing you but on the internet thats impossible. Take it to a shop before you really mess things up.
#40 |
![]() Join Date: Jul 2009
check your injectors, also check your fuel pressure as well, try to use carb cleaner to see if that gets it to at least fire up. also get a fsm if you can and be sure you wired it all correctly, if this is your first time swap by yourself dont be suprised cas we all run into problems on our first one.
#41 |
i probally am gonna take it to get fixed up by sumone who really knows because yea i am a newb n my knowledge is only limited on this but yea im pretty satisfied of how far ive gotten bymyself
![]() -took old engine out -5 speed swap -put the sr in -did the wiring myself from the wiring diagram frsports shows -but yea i just aint all that good yet with the electrical side of this yet lol |
