Old 07-25-2008, 05:19 AM   #1
upstate240sx
upstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really niceupstate240sx is just really nice
sr20det ecu on sr20de
hi,
ive done some searching and i havent found a sure fire answer , but will a rwd sr20det ecu run a sr20de that has been turboed, i kno the sr20det ecu have a coprocessor that runs the direct igniition but can the det ecu run a distributor powered motor?
upstate240sx is offline   Reply With Quote
Old 07-25-2008, 11:06 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Dont think so, your pretty much answered your own question. Rwd DETs run CAS while the DEs run distributors. Maybe with a rom tune its possible...
CLICK HERE!!!
Old 07-25-2008, 11:35 AM   #3
upstate240sx
that i can do...
Old 07-25-2008, 11:47 AM   #4
SoSideways
SoSideways's Avatar
Why not switch to the DET's CAS system if you could?
In any case, getting a DE ECU isn't that hard. Can use the Sentra, or G20's ECUs, IIRC.
Old 07-25-2008, 01:13 PM   #5
upstate240sx
i have a de ecu infact, i have a couple but i bought this jwt ecu not realizing it was tuned for a det, i basically bought a rwd sr20de and turboed using det parts, but using a distributor. how much boost can the stock de ecu run? i also have 370 injectors
Old 07-25-2008, 02:46 PM   #6
SoSideways
SoSideways's Avatar
Oh man, I have no clue.
You might want to sell the JWT ECU and send in one of your DE ECUs and tell JWT to hook you up with a turbo program for it.
Mixing and matching without knowing the specifics of the pros and cons of that setup will only lead you into trouble.
Old 07-26-2008, 01:59 AM   #7
DDDsquad_s13panda
DDDsquad_s13panda is making a name for him/her selfDDDsquad_s13panda is making a name for him/her self
nop wont work.... i tried the same thing too. its better for you jst to go ahead a chipping the ECU. IMO.
but then agian ima be experimenting on it.
DDDsquad_s13panda is offline   Reply With Quote
Old 07-26-2008, 07:19 AM   #8
upstate240sx
what are you experimenting with , a way to rom rune the ecu to run a distributor?
Old 08-04-2008, 03:30 AM   #9
lilaznjeff
lilaznjeff's Avatar
lilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to beholdlilaznjeff is a splendid one to behold
hahaha, currently im doing the same thing right now
i have a s15 sr20de spec s motor
im got a s13 redtop harness and spices out the cam angle sensor,
the coilpacks runs in to the ignitor chip so that means i will be runing a s15 sr20de swap with ignitor chip.
lilaznjeff is offline   Reply With Quote
