Old 07-15-2020, 07:17 AM   #31
s14pit
s14pit is an unknown quantity at this point
You really have built a super clean car.
1989 240sx coupe 2jzge swap
1997 t-100 4x4
s14pit is offline   Reply With Quote
Old 07-15-2020, 01:18 PM   #32
Donedreamin
Donedreamin will become famous soon enoughDonedreamin will become famous soon enoughDonedreamin will become famous soon enoughDonedreamin will become famous soon enoughDonedreamin will become famous soon enough
Lots of sweat equity, and it shows!
Donedreamin is offline   Reply With Quote
Old 07-15-2020, 02:31 PM   #33
TheRealSy90
TheRealSy90's Avatar
I gotta ask where the hell you found brand new ac lines? I'm guessing you're using dohc ka lines and compressor?
Such a good signature.
Old 07-15-2020, 03:43 PM   #34
projectsupra
projectsupra's Avatar
projectsupra is just really niceprojectsupra is just really niceprojectsupra is just really niceprojectsupra is just really niceprojectsupra is just really niceprojectsupra is just really niceprojectsupra is just really niceprojectsupra is just really niceprojectsupra is just really nice
Yea all dohc KA with R134 and PAG46, with the codyace bracket (I wasn't exactly thrilled to pay $70 and open the box to see an aluminum bar, a spacer, and some bolts)
I would have made it myself if I had known that, but I don't mind supporting the community.
The lines and evap core are from that red convertible, they're used, just cleaned up really nice and in great shape.
I am an idiot however, when I stripped that vert I was under the impression I could buy a new condenser so I left it, called everywhere and it's NLA, car was crushed before I could get back.
Took me months to find another good used one.
I did have to carefully bend one of the lines to clear the wastegate actuator and not sit right on the downpipe.
projectsupra is offline   Reply With Quote
Old 07-15-2020, 04:36 PM   #35
S14rebuild
I bought one of codysace brackets like 12 yrs ago sr swap in my s14. Price just came with the swap..cost more to have someone weld up lines that might leak.
Cars lookn good too
Old 07-16-2020, 09:37 PM   #36
projectsupra
I hear that, better to stick with the oem lines.
So it's been a few weeks, jacked the car up for a 500 mile checkup, check all the nuts/bolts, see what vibrated loose, change all the fluids, etc..
Cheap megan DP has been catching road reflectors, it's almost touching the floorboard and I'm not even that low, really need a PBM cobra.
Remember those axles I didn't rebuild, the only thing on the whole car I just bolted on as-is. Well, at some point one of the boots gave out and coated the passenger side underbody in grease.
I looked into Z33 axles but figured there's no point, I'm not making that kind of power and I don't really beat the car enough to justify the swap, maybe one day.
Pulled the axles apart and everything looked decent so we just rebuilt the originals.
Tied on a rag to catch the spring loaded cap.
Also while I had time I CAD up some brackets for a STI strut bar I picked up.
Sent the DXF to a local shop who lasered and bent the plates, threw on some paint and they bolted right up, couldn't be happier.
Also heat wrapped the manifold since it was getting pretty warm under the hood after some spirited driving.
Pulled the thing out and headed to the paint shop to pick up the kouki tail light filler and installed a new OEM center light.
Old 07-17-2020, 04:40 AM   #37
S14rebuild
Nice update, does that strut bar clear with the hood shut? Seems high up
Old 07-17-2020, 06:55 AM   #38
projectsupra
That carbon fiber tube on the STB is maybe 3/4-1" above the valve cover.
It clears my vented hood perfectly, haven't tried the original.
Old 07-17-2020, 09:16 AM   #39
JIMB0
JIMB0's Avatar
JIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really niceJIMB0 is just really nice
you have a lot of talent!!! you should be very proud of all the skills you have Sir!
@JYW0RLD
JIMB0 is offline   Reply With Quote
Old 07-20-2020, 08:55 AM   #40
brndck
brndck's Avatar
Trader Rating: (129)
Feedback Score: 129 reviews
whoa. how much was it to have those strut tower mounts made up?
since I installed my s13.4 valve cover, my STB won't clear any more. This might be a good alternative.
Old 07-20-2020, 09:07 AM   #41
S14rebuild
Im running an ebay one and it clears my s13.4vc...acually closer to my top mount rail..
What mounts are u running?
Old 07-20-2020, 01:44 PM   #42
brndck
brndck's Avatar
i'm not 100% sure. I believe they're Nismo. This car came already sr20 swapped and the seller didn't have the best understanding of everything already done on the car. Lower mounts would prob improve the situation.
Old 07-21-2020, 05:03 PM   #43
projectsupra
IIRC it was $60 or so for the plates, would have been cheaper if I needed more than one pair.
Old 07-22-2020, 12:35 PM   #44
EFITTZY
EFITTZY's Avatar
Another top notch build. Great work saving that chassis. I wish more people had the skill, and dedication to see their project through to the end. Keep it up OP!
(づ。◕‿‿◕。)づ T E A M B L O O M
Old 11-07-2020, 10:05 PM   #45
projectsupra
Really appreciate all the support everyone!
So I haven't posted any build updates in a while because, well, these two smaller twin versions of us joined our family back in April. That of course means the car takes a backseat to everything else, but no worries, at least it's not getting traded in for a minivan as long as I'm still breathing.
But there was one thing I managed to squeeze in so we could enjoy the car as-is for a while. I had planned to retrofit proper bixenon HID projectors in the car since the beginning, and I finally got the chance. Using OEM Denso ballasts, Morimoto D2S 5.0 bixenon projectors, and some OEM philips 85122 bulbs, I'm super happy with the finished product.
After burning through 6lb's of ABS and who knows how many hours of CAD I finally printed enough prototypes to get the alignment, fitment, and deflection where I want it.
The current lexan covers are just temporary so everything is sealed and usable for now, eventually these will be molded to cover the sides as well like originals.
We may even mold the whole assembly in carbon fiber one day if the ABS doesn't hold up well enough.
Also test printed some new shortened pivot arms and purchased M6 spherical joints with shortened rods that correct the open/close height, but that's a project for another day when the twins are a little older.
Best of all, it's all 100% bolt on.
Enjoy the pics and give me some feedback!
Old 11-08-2020, 03:05 PM   #46
Fuglychuki91
Fuglychuki91 is on a distinguished road
The lights look awesome man! And congratulations on the twins! I?m a twin too haha
Fuglychuki91 is offline   Reply With Quote
Old 11-10-2020, 11:02 AM   #47
Thursday7
Thursday7's Avatar
Bless this build
WTB Bride Zieg II
Old 11-10-2020, 12:21 PM   #48
zombiewolf513
Killer build
Old 11-10-2020, 02:57 PM   #49
JrDarknes
JrDarknes's Avatar
I like what you did with the headlights alot. That came out very nice. Very similar to the NA1 NSX except yours looks better.
Instagram: Nismo_Lk
Old 11-10-2020, 06:31 PM   #50
projectsupra
Hooray for twins!
Thanks everyone, sometimes I forget how much work has gone into this car until I look back at this thread
Kinda what I was going for, as low profile as possible, no way to keep a 3 finger gap with a 3" projector lens though.
I've actually helped some friends with NSX headlight swaps long ago before retrofit kits were a thing, those assemblies are huge and super deep, but really nice.
My other option was to use my PIAA PRO 90's (similar NSX lights), I have a few sets but they require cutting the popup housing and light output isn't nearly as good as the Morimoto's.
And just so this post isn't without pics, threw in a USB 3.0 quick charger, first thing on the car that just dropped right in with no mods.
And something not 240 related, pulled the truck out a while back and grabbed some pics.
Old 11-11-2020, 05:45 AM   #51
PoorMans180SX
PoorMans180SX's Avatar
That's the best looking sleepy-eye conversion that has proper lighting I've seen. Let me know if you'd like to sell a set after you get the bugs worked out.
Old 12-14-2020, 08:17 PM   #52
projectsupra
No real updates on the car, but I picked up 3 shiny new old stock coil pack covers someone made while I was looking to buy a new OEM cover. Any ideas who was making/selling these things?
I would have preferred just a no color anodized aluminum, but the red anodizing is kind of growing on me.
Old 12-23-2020, 09:40 AM   #53
Grumbles
Grumbles is an unknown quantity at this point
hard to believe this is the same car you started with, i sold a miata earlier this year because of way less rust. good work
Grumbles is offline   Reply With Quote
Old 12-27-2020, 04:47 PM   #54
Slideurmom
Slideurmom is an unknown quantity at this point
Oof projector lights and ac in a 240 . “Chefs kiss”
Slideurmom is offline   Reply With Quote
Old 12-31-2020, 08:46 PM   #55
projectsupra
Thanks! Always nice to know someone else appreciates the work.
Finally found a few hours to cut and weld the new pivot arm and linkages so the popups work properly. Now the mechanics work just like OEM, just need to wire up the high beam solenoid and mod the combination switch so the "low beam" stays on all the time and high beam activates the high beam shield solenoid.
Old 01-01-2021, 07:02 AM   #56
tuzzio
tuzzio's Avatar
Stripping off anodizing is fairly easy with some oven cleaner.
Old 01-01-2021, 12:02 PM   #57
DRFT180
DRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud of
Where'd you pick up that USB replacement? I've been searching for a slim one to do the same thing.
S14 Build
DRFT180 is offline   Reply With Quote
Old 01-01-2021, 12:39 PM   #58
projectsupra
I found that out the hard way years ago cleaning a nasty engine
Stripped all my nice AN fittings on the block.
Wife found the charger, it's one of the few aluminum bodied ones.
https://www.amazon.com/dp/B07LBLYTST...p_mob_ap_share
Old 01-05-2021, 01:33 PM   #59
JrDarknes
JrDarknes's Avatar
Man that is just too cool. Like another has mentioned. If you ever decide you can sell this as a kit let me know loll. Can't get enough of the low profile headlight look
Instagram: Nismo_Lk
Old 03-07-2021, 05:58 PM   #60
projectsupra
Nothing of substance here, just some updated pics.
Still no diffuser or wing on the car yet
