#211 | |
what kinda fitting did you use for where the line coming off the side of the valve cover goes back into the oil drain? did you use a hose clamp style one? |
#214 | |
![]() Join Date: Oct 2004
This setup was almost designed a year ago LOL! Boy things come back...
Its AN Push Lock Fittings.... and it actually does not drain back to the oil drain. It goes from side breather to catch to turbo. This is used to reduce crank pressure, create as much negative pressure in the valve cover, and drain back oil from the crank to the case via built in oil drainage gallies from the head (stock lol)..... Quote:
Turn and Burn!
#215 | |
and i know what the system does, no need to explain that over and over again like you have been doing. |
#217 | ||
![]() Join Date: Nov 2008
Sure you can clamp hoses on, but you really cant do that with braided lines and you should be using braded lines to get the most out of this setup due to them not closing up under vacuum. Quote:
Yes I do have a can though. Thinking about taking it out of the system however..... |
#218 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Not the bes picture, but it was the first I found I've ran mine like this now for 3 years, without issue or qualm. No oil sprayed anywhere, none in the catch can. I did build her a little tight, but that shouldn't make any difference. I think the biggest 'hindrence' to setups using the intake as the vacuum source (such as my own) is that it will undoubtedly suck oil up out of that rear port. I added the OE oil/air seperator and haven't had an issue since. I skimmed much of this thread, but was really curious as to how sourcing from an unbaffled (unless I missed the part where the added fittings are baffled) part was going to make a worthwhile difference. I would love to just pull off the setup and dump it into the downpipe, but my stuff doesnt' leak/works/isn't an issue...and I'm all about not touching what works.
#219 |
Basically oil will get pulled from the crank case or flung from the crank case on heavy altitude change tracks. I run Laguna and another local track called Thunder where I am going over a really tall hill at top of 3rd.... This vertical G can really slosh the oil in your crank case up to the whole where vac is normally evacuated. With any negative pressure this will suck the oil past the T into a catch can and fill it up in about 2-3 laps.
If you look at the design, it goes from crank case to the valve cover. This design right here is inherent to the valve cover in 2 ways: The input is 1: Lower than where the oil is being sucks out. 2: Where we placed the top fitting that goes to a catch can has a "built in" oil separator from factor. You just have to look at the valve cover design itself. We drilled holes into this separator to allow more suction from our turbo's to create neg pressure in the head and ultimately in the crank case as everything needs to be sealed. 3: The head has built in drainage for oil. This is normal as the head has gallies to drain oil back into the oil pan from the squirters to lube the cams, so hence its closing the system. No oil should ever get into the can because it flows through these gallies back to the pan.... Hope this answers all questions....
Turn and Burn!
#221 |
Seriously F..... cali... Have to do smog now.... so not fun.... But yeah on some of the altitude changes, the front end almost comes off the ground.....
Just gotta make sure you point before lift off lol.....
Turn and Burn!
#222 |
And tagging rumble strips at the apex's can slosh the oil around as well. I feel that many of the people that say that they have ran their setups for X years with no problems more than likely do not track their cars as much as the people that find this to be such a valuable investment. Im not saying thats a bad thing, and if you feel no need in upgrading then by all means spend your money on something you actually can benefit from. With the majority of my miles being on the track, usually over 4k rpms while in boost quite often, my needs are quite different than someone that mostly just drives their car with occasional track time.
And slider, what do you have to do at emissions time? I think if I were to live in cali I would keep a stock motor/intake/exhaust in the garage and swap it out for a few days once a year. You also bring up a good point about liftoff...... If I were to be into road racing instead of drifting and had a very fast car I would go so broke.... Aero that actually works is $$$$, especially stuff for causing front down force. |
#223 | |||
Trader Rating: (58)
Again, that rear port on the block goes to an OEM seperator, which goes the valvecover T, which goes to the catch can, which goes to my intake pipe. On your setup, I see the rear port, dumping into the valve cover, and then a baffled hole on the back half (under that little tray inside the valve cover) going to the catch can...so where yours dumps into the V/C, and then drains back through those holes near the lifters (and the front/rear of the engine), I just stop any oil sucking up at the rear of the motor, with the OE baffled seperator. I guess what I'm getting at, is welding the fittings any better than using the OE baffled seperator...as our setups are similar aside from that. Quote:
In regard to RPM and boost, I totally relate. I've got a 4.6 Final Drive, and a 2871r...I'm always in boost. FWIW We've run FWD cars for years with catch can setups like mine, without issue. I think the biggest advantage is the OE seperator (which FWD has as well) Quote:
I've built over 10 SR's at this point (turbo, n/a, FWD and RWD) and never have issues with cars. As before, I do build my cars fairly tight, but they have no oil consumption issues, have no blow buy, and all still run. Not saying your guy isn't capable, but it seems like something else may be an issue.
#224 | |||
That sounds dandy! What does the 4.6 gear set come out of??? Quote:
Just keep in mind, the old style s13 valve covers with separators on the rear line was discontinued in favor of the s14/15 valve cover design for a reason. People started hacking the 13 and 14 covers up and welding them together for a reason. And this is just a cheaper easier way to end up with the same thing. It is smarter, more efficient and more fool proof/fail safe than the factory design. No one is trying to bully anyone into getting this mod done, and if you dont have the issue with filling up a can (with your setup routed back to intake) then there is no real reason to do this. An easy way to not fill up a can is to pollute with a breather filter instead of routing back to intake, however then you are missing out on power, your car is running off un metered air any time your in vacuum, and your not getting rid of as much crank crase pressure as you can be. If your still spitting oil with a breather filter then you do have a engine problem because there shouldnt be enough crank case pressure to cause oil spatter out of the system and there is no vacuum source to pull it out. |
#225 | |||
Trader Rating: (58)
Sit down for this one...you'll never imagine it...but out of an Xterra Front Pumpkin hehe. The SE models came with 4.6 Final Drives, as well as 4.9!!! Simple bolt (well press too) in affair. It's sorta like S2000 using CRV gearsets haha. Quote:
If there is a better way, and I can easily change it, I'm all about it...but at the same time I don't like changing parts to change them ![]() Quote:
#226 |
Hey you guys hit it right on the nose. In the stock setup there are actually 2 separators. The black can which is the separator, but ALSO in 1 of the pipes between the black can and the black box, there is a restrictor in the pipe. THere is a picture of it somewhere in this thread, but I think this was just a band-aid by nissan. Its actually quite sad they did it this way.
Anyways this is only if you need to eliminate the entire stock setup and do it properly, but this setup also corrects metered and unmetered air and increase negative pressure by completely closing off the system. Some people eliminate the boxes cause they are in the way of equal length manifolds which humps over a lot and the black canister is in the way. In terms of smog, SR's are straight illegal here.... So as we speak I need to get another smog... sigh.... money down the drain...
Turn and Burn!
#228 |
That black thing doesn't work for shit... its the restrictor i the pipe that really blocks stuff out... And with that restrictor and the separator, there isn't much vacuum going to the crank case.... Its been thought up a lot.... hahaha a lot of sleepless nights for me thinking about this.
Turn and Burn!
#229 |
A good expirement to perform.......
Lets get a vac/boost gauge and hook it to the lower tube going to the block. We need someone with a stockish setup and someone with our setup. |
#230 |
Yeah totally... But condition of the block and turbo setup would make a HUGE difference.... Well codyace and your setup seems to be in the best condition.... But how can you measure? You mean T off between the black canister and the crankcase on the back vs. just a vac tube behind us....
But the main thing is this is on boost... LOL its hard to have a very very good comparison.... But great idea.
Turn and Burn!
#231 |
![]() Join Date: Apr 2009
Trader Rating: (38)
so can someone explain to me what the 4.6 final drive actually does? i dont understand gear ratios at all at this point. lol it would be for a drifting aspect, and some road racing.
#232 |
4.6 the higher the number the closer the overall gear ratio, the faster the acceleration. But you also really kill your top speed....
Turn and Burn!
#235 |
Trader Rating: (38)
i actually did read it a couple of times to fully understand it. i know its just right past the E on the top, and i know the pattern that was talked about i just wanted to see the actual pics to get a better idea before i start drilling the valve cover.
#236 | |
Trader Rating: (58)
#237 | ||
Trader Rating: (58)
When I put the 4.6 in the car, I can leave it in the higher gear, and use the mechanical advantage of the gearset to pull me through. Quote:
I love the gears because you can't beat the 2-3rd gear of the car when ripping around....man does it it rip!
#238 |
![]() Join Date: Dec 2002
Can a Mod close this thread? It is getting filled up with shit. We will open a new one with pics, and a complete description to eliminate the confusion.
#239 | |
Trader Rating: (58)
![]() PS: Always enjoy reading your fab pics/posts, even before 'fab forum' Awesome stuff!
