What do u guys think about this for our 240's http://www.jetchip.com/imports/vforce.cfm
Guest
Posts: n/a
After reading claims of the bogus Venom PCM, I'd say don't even bother with this & just commit to the tried & true JWT ECU. The Jet ECU is $200 cheaper though - you're call. Again, don't bother with the PCM.
Guest
Posts: n/a
Venom's claims are not proving. Yes gains are made in mid-range - b/c it's fooling the ECU on the signals from the TPS. Press on the pedal 1/4, the PCM transmits 1/2. On WOT, it has no effect b/c the pedal is at 100% and their nothing to fool. Now, if it remapped fuel curves or altered timing, it'd be useful. Again, just save the money for concrete gains.
