RB25DET Pro Series wiring harness is here!
RB25DET PRO Series Harness: Only $599 for S13 and S14 240sx - ORDER HERE - Limited Quantities so order now!
After much research and development, our highly anticipated RB25DET PRO Series wiring harness has arrived. This sleek new harness is 100% plug and play and comes with a startup guarantee! It was designed in house on an actual RB25DET engine and supports most ECU's, injector types and MAFS. Wiring your RB25 swap has never been easier! PRO-SERIES HARNESS SPECS • Plug and Play. • No cores or additional wiring required. • Point to Point continuity tested on every wire. • Constructed using OEM connectors and seals. • Made with high temp TXL wire (-40C to +125C operating temperature) with adhesive shrink tubing. • Wrapped in lightweight nylon loom with -94C to +257C operating temperature. • Includes a charge harness and improved grounds. PRO-SERIES HARNESS INCLUDES • Quick disconnect MAFS/AEM/Haltech/PFC Speed density extensions (change from MAFS TO AEM/Haltech in seconds). • Coil harness sub-harness. • Knock sensor sub-harness. • Transmission harness with reverse and speed sensor wiring. • Alternator charge cable. • Nissan Diagnostics connector. • OEM Power and dash interface connectors. • Retains factory A/C,speedometer, tachometer, engine temperature gauge, oil pressure sensor, alternator charge light, reverse lights and wipers.
Visit our Website - Check out our Blog - Like us on Facebook - Follow us on Instagram |
![]() Join Date: Jan 2010
nice, do you sell these without the lower harness?? I already have a pro tranny/alt harness.
Right now they can only be ordered as a full set.
Yes we are. It will be out soon actually.
They are on the shelves and ready to ship, let us know if you would like one
![]() Join Date: Nov 2007
![]() ![]() Feedback Score: 19 reviews
I will be contacting you in about maybe a month for a harness. I have a S1 Rb25det engine in my RHD S14. But in my car all my wiring is all rhd jdm from my engine bay, dash, and rear body harness. I see that your site has a listing for S14 RHD Rb25det full harness. So would the harness that you offer be plug and play for me?
![]() Team Prettyboys |
#9 | |
thank you
#12 | |
Here is what we offer for the rb25 neo engines almost ready, we are just finalizing a few more connectors and it will be all set
