Exhaust gasket install help, 7Layer. oem.
Just bought an s15 7-layer exhaust gasket but not sure which side goes were, is it the dark side that contacts block or is it the shiny side?
![]() Join Date: Dec 2009
well you could just slap it on one way or the other and see if you have any problems. haha. I could be wrong but I'm pretty sure it only goes on one way. If not than run the black side on the exhuast manifold.
![]() Join Date: Sep 2005
What side of aluminum does the food go on?
I use the dull side, whether is has a non-stick coating or not!
| exhaust, gasket, nissan, sr20det |
