![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
Yashio Factory Okachan Meter
Used, in great condition. Front panel is in good condition with barely any flaws. Plugs right into consult port.
$162 shipped to USA from Japan.
![]() Join Date: Jan 2014
Dumb question.
Any way to rig it to work with a ka24e? the key feature being the SOHC 240's never had Nissan consult. I know the s13 Stanza with the SOHC KA ECU has the consult port.. But aside from swapping ECU's and my tune, is there a way? |
Trader Rating: (81)
Are you sure there is no consult port? Yea, you can re-wire this to any car. It just reads from your OEM temp sensor. Only thing is figuring out which wires do that. But it shouldnt be that hard as you only need temp signal, ground, 12v for unit power and illumination.
