#3812 |
anyone with pics of a 275/35/18 on a 10.5 rim
need to get the front rim and tire combo which is 245/35/18 on a 9.5 to match and look almost identical with the rear rims and tires ,anything bigger in the front would rub and this tire size looks bess just need help with the back now ,contemplating either 285/30/18 vs 275/35/18 ,whats your input guys |
#3813 | |
![]() Join Date: Mar 2011
#3815 | |
![]() Join Date: Oct 2003
hey that's my old car ! sure would love to know what ever happened to it after i sold it . I'm building its second version now years later really miss it .
-justin |
#3817 |
![]() Join Date: Mar 2009
Front 17x9-4 Volk GT-V
235/40 Federal RS-RR +20mm Origin -6 Camber (I think) & +1" flca. Rear 18x10+2 Volk GT-V 265/35 Kenda KR20 +50mm Origin -1.5 Camber ![]() |
#3818 |
What tires can I fit on the front (9" wide) without stretching? I purchased this vehicle with the following setup:
CHASSIS: s13 WHEELS: XXR 17x9 +35 offset FRONT TIRES: 205/50R17 w/ 1" spacers REAR TIRES: 245/45R17 DETAILS: ISR Pro coilovers The previous owner used this car for autocross, I would like to make it more daily driveable by adjusting the coilovers to raise the ride height a bit, and putting some all-season tires on. The front tires are stretched and the previous owner told me this was necessary to prevent rubbing with the current setup. If I raise the ride height what size tire would fit a 9" wheel on the front without rubbing? ![]() ![]() ![]() ![]() ![]() Last edited by zerog; 06-02-2019 at 04:31 PM.. |
#3819 | |
#3821 |
![]() Join Date: Sep 2009
![]() Wheel/Tire: 18x9.5 +1 w/ 265/35 Kumho SPT 18x12 -7 w/ 315/30 Toyo R888R Alignment: Front Camber: -3 Caster: 7.5 degress Toe: 1/16th Rear Camber -2.5 Toe: 1/8th |
#3822 |
![]() Join Date: Dec 2014
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
![]() ![]() ![]() RS05RR 18X9.5 +22 square. RS-RR 275/35 Def gonna need wider front fenders, but hoping to avoid overs in the rear. I'm gonna try to pull to make it fit. |
#3824 | |
I was running a 17x9 +35 before with a 255/40 square setup. I got a killer price for these (about 50% of retail) and couldn't pass it up. It will also allow me to rotate wheels to keep the wear somewhat even. |
#3825 |
Queztion
On an S13 will 235/40R17's rub on front frame/ wheel well or caster arms?
I just bought some 17x9 +15 and im trying to figure out what tire size to run up front. Thanks |
#3826 |
thinking of running 255/40/17 on 17x9.5 +15 off set square set up on s14. the fender is rolled, RUCA and Fortuneauto coils, It wont be slammed. do u guys think I should run smaller size up front? any issues I may come up on? thanks.
#3827 | |
![]() Join Date: Apr 2011
XXR 551's 17x8.25 +36 215/45-17 fronts 235/40-17 rears (245/40-17 if traction is an issue) Wouldn’t mind knowing if I’d be able to put the 235’s up front. |
#3828 |
Hey Guys,
I’m waiting on coilovers otherwise I’d do the test fitting myself. Would I have an issue running square 265/35 on R34 GT-R wheels 18x9 +30 on my stock body S14? Alternatively, should I stick with 245 series tires? Not looking to stretch or pull the fenders (willing to roll). Tires currently mounted are 11 year old 245/40s. ![]() |
#3831 |
#3832 |
I was going to suggest the same as spooled, but maybe a 15mm spacer in the front depending on your coil overs. 255/35 all around will look nice though.
'98 240sx 5spd |
#3833 | |
Wheels are 17x9 +20 |
#3835 |
#3837 |
Picked up a set of 18x9.5 +15 MB Battles. Shooting for maximum tires. I have 295/35 and 265/35 sitting in my shack at the moment. I do not believe I will be able to run these tires on this setup due to the low offset. What size is recommended?
Front fenders are rolled and rears are slightly pulled. I don't believe my car is that low.. |
#3838 | |
For a 9.5 with a 265/35 in the rear, a +30 and greater would fit without rubbing. Not gonna fit a 265 up front without wider fenders, but 9.5 +15 should clear coilovers with a 265 |
#3839 |
I have a 255 on a 9.5 +7 and it's rubbing when I turn. Would a 245/35 on a 9.5 +15 fix this?
#3840 | |
rubbing the edge of the fender? that'd fix (help) it. that +15 is going to sit 8mm closer to the coil, and thus, 8mm more inboard from the edge of the fender. and the smaller tire size will obviously help. Now, i can assume you are rubbing on both the fender edge and probably fender wells. I was running a 17x9 +35 (20mm spacer so +15 effective). with 3 degrees camber i was poking out quite a bit on the outside, but had ample room between the tire and coil. this was with a 255/40r17 tire. that being said, 245/35 is not max tire on a 9.5 wheel. |
