![]() Join Date: Sep 2015
![]() ![]() ![]() Feedback Score: 2 reviews
SR20DET Loud Screeching
First things first.
Background: This is my first SR and don't know too much about it. I bought the engine from an importer, to my knowledge everything worked, wired it up fine car turns over (needs to be timed to keep it running) Problem: Whenever I turn the car on I'm greeted by a loud screeching noise sounds like coming from the tranny/ starter area. I'm not talking about a quick quiet noise but a loud screech kinda like a belt. It does not go away either it stays with there. Suspicions: I noticed the starter engages when I just press the clutch down or I hear a whirling noise from that area just by pressing the clutch down and not turning the car on. I'm not sure where to go about this any help is useful thanks! |
![]() Join Date: May 2006
Throwout Bearing Or Pilot Beat Bearing One of those but you should replace them.
18g and 20g turbo users click on me #/f/tech-talk/261219-18g-20g-turbo-users.html
If noise occurs with clutch pedal engaged, its the TOB
If noise occurs with clutch pedal at rest, in neutral, its the pilot bushing/bearing. Engine running, obviously. |
Yeah might as well do both if I have to change one. The noise comes from the clutch unpressed so it's not the TOB. Could it be any chance it's the starter? Like it isn't disengaging? I don't want to go through the hassle of taking off my tranny and not fixing the problem...
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
#8 | |
![]() But really I'll start with the starter and if doesn't fix the problem the rest will follow! Thanks guys! |
And replace the Rear Main Seal as well
