When I got my rb20, the tps was completely smashed, and now I don't remember where I put it. I was wondering if anyone knew which tps sensor I can use to replace it, and how to do the wiring?? also, the o2 sensor plug was missing, just 3 wires coming from the sensor and on the harness side, all three wires are brown!! so I don't really know how to connect a spare plug I found onto the harness. anyone ran into these problems??
I'd have to look around to find that TPS substitute, but as far as the O2 sensor, I dont even have mine hooked up. I find it to be no different than when people replace their cat with a test pipe.
Let me do some searching for you, and I'll let you know what I come up with for that TPS.
|OO\____/OO| Okinawa JP 2003-2006 Currently: R14 -- Carolina Nissans Elite |
This is for the R32 RB26DETT, however, sometimes the part numbers are similar, for example both the SR and RB start with 22620-#####. I can look at my RB20 TPS and compair it to the spare SR20 TPS and let you know if they are the same.
Dont get your hopes up, they're probably not the same. But here is the part number for the R32 RB26DETT: 22620-02U00
