Old 12-04-2009, 07:56 PM   #1
kidbandikoot
kidbandikoot's Avatar
kidbandikoot is making a name for him/her selfkidbandikoot is making a name for him/her self
Question H.I.D bulbs
ok its prolly already been askd/postd (whatevr)
any how my question......
i want to get hids i have the stock usdm zenki headlights
so if i bought the hids now, and then bought the glass headlights latr on
(euro spec i believe) would the bulbs be the same, or would i have to buy different bulbs or the whole setup all together
thanx for any info
-KB.
kidbandikoot is offline   Reply With Quote
Old 12-05-2009, 01:00 PM   #2
gregom
gregom is an unknown quantity at this point
I'm assuming your buying aftermarket HID's... so even if they were different bulbs, they are getting cheap you could just buy another set of bulbs. Really you just need to go research what type of bulb fits in the headlamps your going for, and know what you have now.
Only concern would be, if these are projector headlamps, and they are euro spec then they could be setup for right hand drive, which means you will be blinding oncoming drivers because the light steps up on the left side, as opposed to US spec which light steps up on the right side.
gregom is offline   Reply With Quote
Old 12-05-2009, 03:57 PM   #3
projectRDM
projectRDM's Avatar
The glass lamps are German, so they're LHD.
The high beam is a different bulb for the European lights. Lowbeam is the same. You could have searched and found all this without creating yet another thread of rehashed information.
FORMERLY R240NA
