![]() Join Date: Dec 2003
i got what i think is a t3/t04e turbine, already installed. also just got in the mail the jgs tools oil line kit. for some reason, the fitting feeding the turbine is too small.. this is the second line kit i've ordered, dont remember where i got the first one from. how can i figure out exactly what size turbo i got? also, what kinda fitting i need to feed it?? if anyone could point me in the right direction, i'd greatly appreciate it!
thanks a lot!
LAID OUT
![]() Join Date: Mar 2004
Sorry to get off topic here, I can't help you with the line question.
Just wanted to say that, damn your turbine housing is close to your MBC. What happens when the engine rocks under accel? And what are you planning to do to stop the heat transfer to the MBC? GL with your lines... |
thats cause the car used to be an auto, and had a chubby brake booster that pushed the mc forward. i'm replacing that with a manual version, so that should help with the clearance issues.
as far as the lines go, ok, if i get the 1/4 to 1/8 bushing or adaptor, how would i fit an oil pressure restrictor on the housing then? these oil lines are really starting to get on my nerves.........
![]() Join Date: Apr 2004
Your best bet is to contact Harp at Taka Motorsports. He does this stuff every day and can get you exactly the lines you need.
http://takamotorsports.com/ |
