NX Cluster for RB25
I just purchased the NX digital cluster and wanted to know if it can be wired to an RB25? If it can, does it only work with a stock ecu or will it work with a nistune as well?
![]() Join Date: Sep 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
itll will work with a RB25, ive wired one up for a RB25DET NEO before. you will need a tach converter to get tach speed right.http://www.dakotadigital.com/index.c...rod/prd127.htm
the speedo will be correct as long as you have the right color gear on the VSS to match your final drive. |
