max front lower control arm & solid steering column bushing
im a noob having said that i have two question
1- when extending max's front lower control arm to the "max!" how to push the knuckle outwards to reinstall the extended arm to the knucke do i need to loosen some bolts to do that or sjust push it out 2- installing the solid steering column bushing do u need to in a way move the engine or you can simplt change it from below Thanks guys |
#2 | |
![]() Join Date: May 2009
You can get to it from inside the engine bay with out moving anything if you really work at it, or you can pull the steering column from inside the cabin to get to the bushing.
