![]() Join Date: Sep 2013
I've been looking all over for some info on this & I cannot find anything.
Problem: When it's hot outside the car has a hard time starting and it takes 2-3 turns of the ignition. The car will finally turn over and will have a rough idle for 5 or so seconds and then acts completely normal. If it's cold out or I have the car in the shade it starts normally. Anyone have this symptom before? FPR? Injectors? Vacuum? Fuel Filter? EDIT: UPDATED WITH VIDEO I'm starting to think maybe it's something with timing possibly. I've been busy with work & haven't had time to mess with it. Here's a video (couldn't get Zilvia to embed the video) http://youtu.be/M95MAbLmB4o Last edited by FLG; 05-22-2014 at 07:17 AM.. |
![]() Join Date: May 2013
Try finding a FSM. Go to section EC and go to page 66 if I'm correct. Its somewhere in the area. I know this because I had the same problem. Funny thing is I had both it was hard to start in the morning and sometimes hard to start when it was hot.
GM2 (SW/AW)
My first car had a starting issue when it got hot out, I never figured it out. it had a cut exhaust and stock ka24e. nothing modded.
A phenomena to this day.
| hot, rough idle, starting, weather |
