Anyone used and installed the walbro 416lph e85 compatible.?
Has anyone use the walbro 416 lph fuel pump? Im planing on using this fuel pump but want to know if any of you guys had good outcome with this fuel pump before I buy one. I plan on using e85 with id or fic 2000cc injectors. Let me know guys and I will appreciate it. Thanks.
![]() Join Date: Aug 2011
You are on zilvia, land of (mostly ) ricers and fanbois driving battleship earth height rotten cars (how to make friends 101: call everyone retards
)Ok they are not all like that. But i cant think of anyone here that would need that kind of fueling system ... Maybe you should try your luck on NRR. It looks like you are going for some serious power here. Any build thread / objective ? |
#4 | |
-95 S14 Swap with fully stock Auto Aristo 2jzgte swap -Precision 6776 Turbo -AEM V2 -completely stock motor. -built auto tranny from boost logic w/3800 stall. -4bar map sensor -FIC2000cc injectors Now yes, i know we are on zilvia.net and yes i am looking for some power because I know stock 2jzgte motors are monsters and can make easy hp and realiable.!. Anyways, I'm shooting between 600-700hp. Now, I am wondering has anyone use the in-tank walbro 416lph fuel pump in the 240's.? And also will i have to do any modifications to hook up the fuel pump into the tank. Anyone that has done the walbro 400 let me know if there is any modifications that I will need to do in order to make it work. |
I have this pump in my EVO with ID2000 injectors. It supported 515AWHP on e85 on my 2.0 4G63. I'm putting in a 2.4L now but it will be on pump gas, this pump will easily support 500AWHP on pump gas. I heard the limit on e85 is 550-600HP. Not sure though. My tuner says he's never maxed one out.
#10 | |
Yep, my buddy put down 830whp in his Supra on race with dual 255's.
My SR20VET |
