s13 ebrake cable questions
i have an s13 hatch an just did a s14 5lug an big brake conversion an noticed that the e brake cable ends are different so i was wondering if i got e brake cables off an s14 would they work? or am i going to have to do a lot of modifying?
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
WHAT?? what "big brake conversion" did u do in the back?? are u trying to use s-14 calipers in the rear?? why? just use the stock s-13 calipers
no it is just in the front but 5 lug all way around an the ebrake end links an different on the s13 an 14 an was wondering tho what all ill need to hook the ebrake back up
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
wait so you only upgraded the front brakes but your asking what you need for the for stock rear brakes? calipers are the same for s13 and s14 and as far as i know the only difference between the s13 and s14 cables is the length.
- Jimmy Wanted: TBD For Sale: TBD |
#6 | |
IIRC the difference in between the s-14 and s-13 caliper is the "horseshoe" where the cable attaches to the caliper. which is why OP cant use s-14 rear calipers on s-13...
Trader Rating: (54)
ahh your right, but on the caliper that piece should be able to be swapped over for the s13's right?
i dont know for sure yet its got that little pin in the way i was thinking about shaving it off a little so i could slide it off then just switch the over like that an the just weld up an edge back on the s14 one
