S13/S14/Z32/Z33 random parts cheap sale
cleaning out the garage.. lmk. everything obo or else it goes in the trash.
S13 Front Sway Bar - $10 S13 Rear Sway Bar - $10 S13 tail lamp set - $20 S13 open diff - $40 S13 e-brake lines - $10 S13 SOHC power steering pump - $20 S13 Rear upper control arms (pair) - $10 S13 Rear toe arms (pair) - $10 S13 Rear traction arms (pair) - $10 S13 Front tension arms (Pair) - $10 S13 Front lower control arms (pair) - $20 S13 passenger side rear axle - $10 S13 non-abs master cylinder - $5 S13 clutch master cylinder - $5 S13 transmission mount - $10 S13 hatchback quarter panel interior plastic - $10 each S13 power window rails - $5 each S13 rear driver side spindle - free S13 rear 4-lug hub - $5 S13 sohc ac evaporator housing + evaporator - $20 S13 front top hats - $20 S13 sohc intake box+tube+maf - $10 S13 misc crap - $5 each 300ZX rear differential mount (fresh black powdercoat) - $20 350Z Power Steering pump - $40 350z brake booster - $30 350z Non-brembo master cylinder - $20 350z aluminum motor mounts - $20 each will post pictures later tonight EDIT 6/17/12: Found a couple brand new items still in original package and never opened. Just throwing this out there see if anyone is interested. Can provide pictures if needed. Mishimoto Universal 10-row Oil Cooler Kit - $175 This kit comes with everything needed for remote oil cooler installation. Comes with sandwhich adapter and oil lines. More information can be found: http://www.mishimoto.com/mishimoto-u...ooler-kit.html Circuit Sports Oil Cooler Relocation Kit - $100 Kit comes with everything needed for oil cooler relocation. Comes with sandwhich adapters, fittings, and oil lines. More information can be found: http://www.circuit-sports.com/produc...&category_id=4 call me at (5six2) 3nine6-7643 Last edited by jachien; 06-17-2012 at 11:33 AM.. Reason: new parts added. |
