#1 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
Swap ratings and other info
There are many swap ideas out there currently that are possible. They vary in difficulty, performance, cylinders, and ease of aquiring. I have created this page as a way for people to quickly decide what engine swap they want to do. The first idea isn't a swap at all, merely just turboing your stock KA, while this may seem stupid compared to the hp gains of other swaps you must also think about how cheap it is to do and how much potential your stock engine really has. In many cases a front clip is important and can make the installation troublesome and very costly with just the engine. Always try to get a clip instead of just the engine.
You may want to know what the engine codes for each engine stands for. You can find that here. For a list of links to get a swap done or buy a clip/engine click here. 1= N/A 2 = Hard / Poor 3= Moderate / Fair 4 = Easy / Good [navigation] | I4 | I6 | V6 | | KA series | CA series | SR series | RB series | VG series | VQ series | | KA24DET | CA18DET | SR20DET | RB20DET | RB25DET | RB26DETT | RB30DET | 2JZGTE | VG30DETT | VQ30DE | VQ35DE | Turbo KA24DE [more info] Swap Difficulty: 1 Aftermarket Support: 3 Donor Car(s): S13 (1991+ US model), S14 (all US models) Stock Horsepower: 155hp (157ps) @ 5600rpm *before turbo install* Stock Torque: 160lb/ft (22.2kgm) @ 4400rpm *before turbo install* Redline: 7,000rpm Good: cheap, fast, less work than a swap Bad: reliability issues in some cases when running med/high boost sustained Engine Cost: $800-1,500 (a few hundred more if it's rebuilt or has some parts upgraded/strengthened) Install Cost: n/a (everything is installed other than turbo) OR $200-500 (to install a new KA where your old KA was) Modified Horsepower Ceiling (stock internals): 250-350hp CA18DE-T [more info] Swap Difficulty: 4 Aftermarket Support: 4 Donor Car(s): Silvia (1989-1990) and 180sx (japan) Stock Horsepower: 173hp (175ps) @ 6400rpm Stock Torque: 166lb/ft (23.0kgm) @ 4000rpm Redline: 8,500rpm Good: higher redline and cheaper than SR20DET with about the same potential, iron block Bad: less parts support (esp in the US), weaker head gasket than SR20DET Engine Cost: $2,000-3,000 Install Cost: $1,000-2,000 Modified Horsepower Ceiling (stock internals): 300-400hp SR20DE-T (S13) [more info] Swap Difficulty: 4 Aftermarket Support: 4 Donor Car(s): Silvia K (japan), Kouki 180SX Stock HP: 203hp (205ps) @ 6000rpm Stock Torque: 202lb/ft (28.0kgm) @ 4000rpm Redline: 7,500rpm Good: great output for the price with very good potential Bad: less output than an RB25 and weakest (stock) SR20DET, aluminum block Engine Cost: $2,500-3,500 Install Cost: $1,000-2,000 Modified Horsepower Ceiling (stock internals): 350-450hp SR20DE-T (S14) [more info] Swap Difficulty: 4 Aftermarket Support: 4 Donor Car(s): Silvia K (japan) Stock Horsepower: 217hp (220ps) @ 6000rpm Stock Torque: 202lb/ft (28.0kgm) @ 4800rpm Redline: 7,500rpm Good: slightly better output than the S13 SR20DET Bad: VVT can be an issue when modifying heavily, aluminum block Engine Cost: $4,000-5,000 Install Cost: $1,000-2,000 Modified Horsepower Ceiling (stock internals): 350-500hp SR20DE-T (S15) [more info] Swap Difficulty: 4 Aftermarket Support: Donor Car(s): Silvia K (japan) Stock Horsepower: 247hp (250ps) @ 6400rpm Stock Torque: 202lb/ft @ 4800rpm Redline: 7,500rpm Good: ~250hp stock, usually very low mileage, better condition than s13 or s14 engines (in most cases) Bad: 6 speed tranny is somewhat weak, so if you plan to increase the hp much you want to swap it for the ka tranny or an s13/14 tranny, VVT can be an issue when modifying heavily, aluminum block Engine Cost: $5,000-6,000 Install Cost: $1,000-2,000 Modified Horsepower Ceiling (stock internals): 350-500hp RB20DE-T [more info] Swap Difficulty: 3 Aftermarket Support: 3 Donor Car(s): Skyline GTS-T (1989-1992), Cefiro (sedan) Stock Horsepower: 215hp (210ps) @ 5600rpm Stock Torque: 180lb/ft (25.0kgm) @ 4000rpm Redline: 8,000rpm Good: deeper engine sound, stronger than the SR20DET, more stock horsepower, iron block Bad: cost Engine Cost: $800-18,000 Install Cost: $2,000-2,500 Aftermarket Support: Fair Modified Horsepower Ceiling (stock internals): 400-450hp RB25DE-T [more info | SCC article] Swap Difficulty: 3 Aftermarket Support: 4 Donor Car(s): Skyline GTS-25T (1993-1994) Stock Horsepower: 247hp (250ps) @ 6000rpm (R33; 1994-1997), 277hp (280ps) (R34; 1998-2003) Stock Torque: 217lb/ft (30kgm) @ 4800rpm Redline: 8,000rpm Good: deeper engine sound, stronger than the SR20DET, more stock horsepower, iron block Bad: cost, replacement parts availability Engine Cost: $5,000-6,500 Install Cost: $2,500-3,000 Modified Horsepower Ceiling (stock internals): 400-450hp RB26DE-TT [more info] Swap Difficulty: 2 Aftermarket Support: 4 Donor Car(s): Skyline GTR (R32,R33,R34) Stock Horsepower: 316hp (320ps) @ 6800rpm Stock Torque: 289lb/ft (40.0kgm) @ 4400rpm Redline: 8,000rpm Good: huge potential, high horsepower stock, iron block Bad: AWD tranny can't be used without lots of modification and custom work. TT setup can be retained, but it's much easier to convert it to a single turbo. RB25 tranny (5 speed rather than RB26 6 speed) because of clearence and fit issues. Engine Cost: $7,000-8,000 Install Cost: ~$3,000 (AWD and TT setup will be in excess of $15,000 for install) Modified Horsepower Ceiling (stock internals): 500-600hp RB30DE-T (hybrid) [more info | head conversion how-to] Swap Difficulty: 3 Aftermarket Support: 3 Donor Car(s): Australian (block; RB30ET 3.0L SOHC) / Skyline GTR or GTS-T (head; RB25, RB26, or RB20) Stock Horsepower: ?hp (?ps) @ ???rpm Stock Torque: ?lb/ft (?kgm) @ ???rpm Redline: Good: good potential, iron block, cheap engine, when modified produces large hp numbers at low revs Bad: age, replacement parts availability, block is hard to find, RB20 head requires lots of work to fit correctly Engine Cost: n/a Install Cost: ~$3,000 Modified Horsepower Ceiling (stock internals): 350-400hp 2JZ-GTE [more info | 300sx conversion!] Swap Difficulty: 2 Aftermarket Support: 4 Donor Car(s): Supra TT (1991-1998) Stock Horsepower: 320hp (327ps) @ 5800rpm Stock Torque: 315lb/ft (43.8kgm) @ 4000rpm Redline: 6,800rpm Good: great potential, amazing engine, .4 liters more than RB26, iron block, engine isn't imported Bad: different motor mounts, more custom fabrication than RB26, non-nissan engine Engine Cost: $2000 or less Install Cost: $11,000 Modified Horsepower Ceiling (stock internals): 550-650hp VG30DE-TT [more info] Swap Difficulty: 2 Aftermarket Support: 4 Donor Car(s): 300ZX TT Stock Horsepower: 300hp (304ps) @ 6400rpm Stock Torque: 283lb/ft (39.3kgm) @ 3600rpm Redline: Good: very unique and a decent engine for heavy modification Bad: huge cost for custom fabrication Engine Cost: $4,000-6,000 Install Cost: $10,000-20,000+ Modified Horsepower Ceiling (stock internals): 450-550hp VQ30DE(K) [more info] Swap Difficulty: 2 Aftermarket Support: 3 Donor Car(s): VQ30DE in A32 Maxima(1995-1999 US model), VQ30DEK in A33 Maxima(2000-2001 US models) Stock Horsepower: 190 hp @ 5600 rpm(A32 VQ30DE), 222hp @ 6400rpm(A33 VQ30DEK) Stock Torque: 205 lb ft @ 4000 rpm(A32 VQ30DE), 217 lb ft @ 4000rpm(A33 VQ30DEK) Redline: 8,000 rpm Good: Can be cheap, good low-end, lightweight, very turbo friendly for an NA motor. Bad: lack of top end on non DEK motors. Note: Can be fixed with variable intake manifold from Courtesy Nissan. Needs Pathfinder tranny. Engine Cost: $400+ Install Cost: N/A Modified Horsepower Ceiling (stock internals): 350-400hp VQ35DE [more info] Swap Difficulty: 2 Aftermarket Support: 2 Donor Car(s): 350Z, G35, kouki Maxima, kouki Altima, kouki Pathfinder Stock Horsepower: 287hp (291ps) @ 6,200rpm (350z/G35), 245hp (249ps) @ 5,800rpm (Altima) Stock Torque: 274lb/ft (38.0kgm) @ 4,800rpm (350z/G35), 246lb/ft (34.2kgm) @ 4,400rpm (Altima) Redline: 6,600rpm Good: very unique and a decent engine for heavy modification Bad: huge cost for custom fabrication, engine taken from a kouki Altima or Maxima will need a RWD trans Engine Cost: $5,000-7,500 Install Cost: $10,000-20,000+ Modified Horsepower Ceiling (stock internals): n/a (350-400hp est.) VH41DE [more info | pics ] Swap Difficulty: 2 Aftermarket Support: 2 Donor Car(s): Infiniti Q45, Cima (J) (Both also came with the VH45DE as well). Stock Horsepower:340 HP @ 6,400 rpm (taken from automotive.com, specs for 2001 VH45DE) Stock Torque: 333 ft lb @ 4,000 rpm Redline: 6,600rpm Good: huge torque at low rpm Bad: possible weight distribution issues Engine Cost: n/a Install Cost: n/a Modified Horsepower Ceiling (stock internals): n/a
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got
#2 | |
New and updated info would be greatly apprciated
![]() -Edit and no I didnt do all the swaps I just found this searching for answers ![]()
#3 | |
More Detailed Engine/Tranny spec's
Turbo KA24DE
General Specs Engine Type: 2.4L I4 (Turbo) DOHC Stock Horsepower: 155hp (157ps) @ 5600rpm *before turbo install* Stock Torque: 160lb/ft (22.2kgm) @ 4400rpm *before turbo install* Redline: 7,500rpm Dimensions (with manual tranny): Engine/Trans. Weight: 540lb (KA24E: 492lb) *before turbo install* Weight Distrubition After Swap: N/A Internal Specs Displacement: Compression: 9.2 : 1 (178psi standard, 149psi minimum) Bore & Stroke: 89mm x 96mm Injector size: Bolt-On Specs Turbo: n/a (various options depending on needs) Stock Boost: n/a (various options depending on needs) A/R Ratio: n/a (various options depending on needs) Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 8.20 seconds *before turbo install* 1/4 Mile (400km): 16.10 seconds *before turbo install* Top Speed: 122 mph (195kph) -------------------------------------------------------------------------------- CA18DE-T General Specs Engine Type: 1.8L I4 Turbo DOHC Stock Horsepower: 173hp (175ps) @ 6400rpm Stock Torque: 166lb/ft (23.0kgm) @ 4000rpm Redline: 8,500rpm Dimensions (with manual tranny): Engine/Trans. Weight: Weight Distrubition After Swap: 50/50 Internal Specs Displacement: 1809cc Compression: 8.5 : 1 Bore & Stroke: 83mm x 83.6mm Injector size: 370cc Bolt-On Specs Turbo: T-25 Stock Boost: A/R Ratio: 0.48 Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 1/4 Mile (400km): Top Speed: 122 mph (195kph) -------------------------------------------------------------------------------- SR20DE-T (S13) General Specs Engine Type: 2.0L I4 Turbo DOHC Stock Horsepower: 203hp (205ps) @ 6000rpm Stock Torque: 202lb/ft (28.0kgm) @ 4000rpm Redline: 7,500rpm Dimensions (with manual tranny): Engine/Trans. Weight: 490lb Weight Distrubition After Swap: 50/50 Internal Specs Displacement: 1998cc Compression: 8.5 : 1 (171psi standard, 142psi minimum) Bore & Stroke: 86mm x 86mm Injector size: 370cc Bolt-On Specs Turbo: T-25 Stock Boost: 7psi A/R Ratio: 0.80 Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 6.18 seconds 1/4 mile (400km): 14.30 seconds topspeed: 112 mph (180kph) -------------------------------------------------------------------------------- SR20DE-T (S14) General Specs Engine Type: 2.0L I4 Turbo VVT DOHC Stock Horsepower: 217hp (220ps) @ 6000rpm Stock Torque: 202lb/ft (28.0kgm) @ 4800rpm Redline: 7,500rpm Dimensions (with manual tranny): Engine/Trans. Weight: Weight Distrubition After Swap: 50/50 Internal Specs Displacement: 1998cc Compression: 8.5 : 1 Bore & Stroke: 86mm x 86mm Injector size: 370cc Bolt-On Specs Turbo: T28 ball-bearing Turbo Stock Boost: 7psi A/R Ratio: 0.64 Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual 3.321 1.902 1.308 1.000 0.838 N/A 3.382 3.692 (Turbo) 4.083 (NA) Automatic 2.785 1.545 1.000 0.694 N/A N/A 2.272 3.916 (Turbo) 4.083 (NA) Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 6.30 seconds 1/4 mile (400km): 13.55 seconds topspeed: 112 mph (180kph) -------------------------------------------------------------------------------- SR20DE-T (S15) General Specs Engine Type: 2.0L I4 Turbo VVT DOHC Stock Horsepower: 247hp (250ps) @ 6400rpm Stock Torque: 202lb/ft (28.0kgm) @ 4800rpm Redline: 7,500rpm Dimensions (with manual tranny): Engine/Trans. Weight: Weight Distrubition After Swap: 50/50 Internal Specs Displacement: 1998cc Compression: 8.5 : 1 Bore & Stroke: 86mm x 86mm Injector size: 480cc Bolt-On Specs Turbo: T28 ball-bearing turbo Stock Boost: 9psi A/R Ratio: 0.64 Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual (Turbo) 3.626 2.200 1.541 1.213 1.000 0.767 3.437 3.692 Manual (NA) 3.321 1.902 1.308 1.000 0.838 N/A 3.382 4.083 Automatic 2.785 1.545 1.000 0.694 N/A N/A 2.272 3.916 (Turbo) 4.083 (NA) *turbo manual uses helical LSD *turbo auto uses viscous LSD *n/a doesn't have LSD (LSD an option?) Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 5.60 seconds 1/4 mile (400km): 13.90 seconds topspeed: 112 mph (180kph) -------------------------------------------------------------------------------- RB20DE-T General Specs Engine Type: 2.0L I6 Turbo DOHC Stock Horsepower: 207hp (210ps) @ 5600rpm Stock Torque: 180lb/ft (25.0kgm) @ 4000rpm Redline: 8,000rpm Dimensions (with manual tranny): Engine/Trans. Weight: Weight Distrubition After Swap: ~50/50 Internal Specs Displacement: Compression: 8.5 : 1 Bore & Stroke: 78mm X 69.7mm Injector size: Bolt-On Specs Turbo: Stock Boost: A/R Ratio: Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): ??? 1/4 mile (400km): ??? topspeed: ??? -------------------------------------------------------------------------------- RB25DE-T General Specs Engine Type: 2.5L I6 Turbo DOHC Stock Horsepower: 247hp (250ps) @ 6000rpm Stock Torque: 217lb/ft (30.0kgm) @ 4800rpm Redline: 8,000rpm Dimensions (with manual tranny): Engine/Trans. Weight: 720lb Weight Distrubition After Swap: ~50/50 Internal Specs Compression: 8.8 : 1 Bore & Stroke: 86mm X 71.7mm Injector size: Bolt-On Specs Turbo: Stock Boost: A/R Ratio: Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): ??? 1/4 mile (400km): ??? topspeed: ??? -------------------------------------------------------------------------------- RB26DE-TT General Specs Engine Type: 2.6L I6 Twin-Turbo DOHC Stock Horsepower: 316hp (320ps) @ 6800rpm Stock Torque: 289lb/ft (40.0kgm) @ 4400rpm Redline: 8,000rpm Dimensions (with manual tranny): 870mm x 665mm x 675mm Engine/Trans. Weight: 790lb Weight Distrubition After Swap: Internal Specs Displacement: 2568cc Compression: 8.5 : 1 Bore & Stroke: 86mm X 73.7mm Injector size: Bolt-On Specs Turbo: Twin Garrett ball-bearing ceramic turbos Stock Boost: 0.6 bar (R33) A/R Ratio: Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual R32/R33 3.214 1.925 1.302 1.000 0.752 ? 3.369 4.111 R34 3.827 2.360 1.686 1.312 1.000 0.793 ? 3.545 Automatic *most swaps will use the RWD GTS-T Skyline RB25DET RWD Tranny Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 1/4 Mile (400km): Top Speed: -------------------------------------------------------------------------------- RB30DE-T (hybrid) General Specs Engine Type: 3.0L I6 Turbo DOHC Stock Horsepower: ?hp (?ps) @ ???rpm Stock Torque: ?lb/ft (?kgm) @ ???rpm Redline: Dimensions (with manual tranny): Engine/Trans. Weight: Weight Distrubition After Swap: Internal Specs Displacement: Compression: 8.5 : 1 Bore & Stroke: 86mm x 86mm Injector size: Bolt-On Specs Turbo: Stock Boost: A/R Ratio: Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 1/4 Mile (400km): Top Speed: -------------------------------------------------------------------------------- 2JZ-GTE General Specs Engine Type: 3.0L I6 Twin-Turbo DOHC Stock Horsepower: 320hp (327ps) @ 5800rpm Stock Torque: 315lb/ft (43.8kgm) @ 4000rpm Redline: 6,800rpm Dimensions (with manual tranny): Engine/Trans. Weight: Weight Distrubition After Swap: Internal Specs Displacement: 2997cc Compression: 8.5 : 1 Bore & Stroke: 86mm x 86mm Injector size: 540cc Bolt-On Specs Turbo: Steel CT12B Stock Boost: A/R Ratio: 0.53 Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual 3.827 2.360 1.685 1.312 1.000 0.793 3.280 3.133 Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 1/4 Mile (400km): Top Speed: -------------------------------------------------------------------------------- VG30DE-TT General Specs Engine Type: 3.0L V6 Twin-Turbo DOHC Stock Horsepower: 300hp (304ps) @ 6400rpm Stock Torque: 283lb/ft (39.3kgm) @ 3600rpm Redline: Dimensions (with manual tranny): Engine/Trans. Weight: Weight Distrubition After Swap: Internal Specs Displacement: Compression: 8.5 : 1 Bore & Stroke: Injector size: Bolt-On Specs Turbo: Stock Boost: A/R Ratio: Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 1/4 Mile (400km): Top Speed: -------------------------------------------------------------------------------- VQ30DE(K) General Specs Engine Type: 3.0L V6 DOHC Stock Horsepower: 190hp (193ps) @ 5600rpm (A32 VQ30DE), 222hp (225ps) @ 6400rpm (A33 VQ30DEK) Stock Torque: 205lb/ft (28.4kgm) @ 4000rpm (A32 VQ30DE), 217lb/ft (30.1kgm) @ 4000rpm (A33 VQ30DEK) Redline: 8,000rpm Dimensions (with manual tranny): Engine/Trans. Weight: Weight Distrubition After Swap: Internal Specs Displacement: Compression: 10 : 1 Bore & Stroke: 93mm x 73.3mm Injector size: Bolt-On Specs Turbo: N/A Stock Boost: N/A A/R Ratio: N/A Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 1/4 Mile (400km): Top Speed: -------------------------------------------------------------------------------- VQ35DE General Specs Engine Type: 3.5L V6 DOHC Stock Horsepower: 287hp (291ps) @ 6,200rpm (350z/G35), 245hp (249ps) @ 5,800rpm (Altima) Stock Torque: 274lb/ft (38.0kgm) @ 4,800rpm (350z/G35), 246lb/ft (34.2kgm) @ 4,400rpm (Altima) Redline: 6,600rpm Dimensions (with manual tranny): Engine/Trans. Weight: Weight Distrubition After Swap: Internal Specs Displacement: Compression: 10.3 : 1 Bore & Stroke: 95.5mm x 81.4mm Injector size: Bolt-On Specs Turbo: N/A Stock Boost: N/A A/R Ratio: N/A Transmission Specs (350z/G35) 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual 3.794 2.324 1.624 1.271 1.000 0.794 3.446 3.358 Automatic 3.540 2.264 1.472 1.000 0.834 N/A 2.370 3.357 Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 1/4 Mile (400km): Top Speed: -------------------------------------------------------------------------------- VH41DE General Specs Engine Type: 4.1L V8 DOHC Stock Horsepower: 266hp (270ps) @ 5600rpm Stock Torque: 277lb/ft (38.4kgm) @ 4000rpm Redline: Dimensions (with manual tranny): 4970mm X 1820mm X 1445mm Engine/Trans. Weight: 1750kg Weight Distrubition After Swap: Internal Specs Displacement: 4130 Compression: 10.5 : 1 Bore & Stroke: 98.0mm × 76.0mm Injector size: Bolt-On Specs Turbo: N/A Stock Boost: N/A A/R Ratio: N/A Transmission Specs 1st 2nd 3rd 4th 5th 6th Reverse Final Drive Ratio Manual Automatic Performance (stock engine installed on 240sx/silvia) 0 - 60 mph (0-100km): 1/4 Mile (400km): Top Speed:
#4 | |
Courtesy of - http://klohiq.tripod.com/cars/240sx/
