| South Central States Arkansas, Kansas, Louisiana, Missouri, Oklahoma, and Texas. |
![]() Join Date: Oct 2012
new from dfw
names brandan i just sold my 500+whp 98 civic and picked up a 95 240sx se ([email protected] old car)
plans are a 2j swap it will be a street/strip car i bought the car how it sits with out the volks Chassis: Silvia Grill V-Tund Front Lip Kouki Side Skirts Kouki Tail Lights Gracier Rear Valences Seibon OEM Style Hood and Trunk New OEM Headlights Orange Tinted Turns and Sidemarkers Limo tinted windows, fronts are 35% Rolled Rear Fenders Suspension, Wheels, and Brakes: K Sport Kontrol Pro Coilovers SPL Tension Rods SPL Rear Subframe Spacers Tein Inner and Outer Tie Rods Z32 Aluminum Front 30mm Calipers with OE Rotors and Pads OE S14 Rear Disks and Pads SPL SS Brake line all around 350z wheels Drivetrain Built S13 SR20DET Blacktop - CP 20 over 9:1 Pistons, Carrillo H-Beam Rods, HKS Head Package with 264 Step 2 Cams, ARP Head/Mainstuds, Cometic MLS Headgasket AEM EMS V1 with 3.5 Bar MAP Sensor and IAT Sensor Wiring Specialties Engine/Transmission Harness Tomei M8270 Turbine Kit ISIS Intake Manifold with ISIS Coldpipe JGY Customs Fuel Rail with Injector Dynamics 1000CC Injectors Aeromotive FPR AEM Methonal Injection Touge Factory High Pressure P/S Line Greddy RAS HKS Oil Filler Cap Greddy Catch Can Titek Carbon Fiber Coil Pack Cover Walbro 255 Fuel Pump Top Speed Pro 1 Aluminum Pulleys - Polished Nismo Thermostat Koyo Aluminum Radiator Blue Silicone Hoses Flex A Lite Fans HKS SSQV3 BOV Custom Intake Pipe, NO MAF Greddy Spec M FMIC Top Speed Pro 1 Turbo Elbow Project Nissan 3 inch DP Boost Logic 3 inch Test Pipe Tomei Expreme Titanium Exhaust RPS MAX Street Clutch with OEM Flywheel coustom Fast-Turbo.com SS Clutch Line C's Short Shifter S14 VLSD Diff Interior: Custom Triple 52mm Gauge Pod AEM Wideband Failsafe Gauge AEM Datastream Serial Gauges x2 Greddy Profec B Spec 2 Eclipse Deck S15 Steering Wheel Converted Interior from Green/Blue Finish to Black for those that dont know the car |
