Ikeya formula sequential shifter issue
Hello guys,
I just installed my new sequen shifter on my s13 ca18det but I have a problem with the reverse gear. I take the type 1 and my gearbox is a type 2 "the reverse gear with a longer distance than the other gear". My problem is only with the reverse gear, the shifter don't push the lever suficiently long for entre totaly the gear and we I move the car the gear go out ! On the website of Ikeya I see that on the type 1 and type 2 the difference is on the Y of the lever, the type 2 as one part shorter and the type 1 the both extremity are at the same leng. There is one personne who made this modification?? |
![]() Join Date: Aug 2011
I know "sequential gearbox" might sound cool, but what you actually want is a dogbox transmission, with synchros on 1st/reverse. And then add a sequential command to it.
But that kind of thing is surely worth 5 times the worth of the car. Do yourself a favor and bin that piece of crap, it does not make your gearbox faster and will just kill your synchros. |
I know that this part don t make faster the gear change but I like it. The next year I will put one sr20det with a rb25 gearbox, this year I just would make the sequen shifter workijg good with my reverse gear
And the RB25 is not that much stronger than the sr20 box. If you want a really strong and modern one, the later Z33 gearbox is great. Precise, gears go in like it is made of butter, it has 6 speed although the 1st really is short. But that is like 5K€ to make the swap (that includes a brand new gearbox, a custom driveshaft, adapter plate, machining and labor)
