![]() Join Date: Dec 2006
i thought i rechecked everything and now i have this plug wire that i think is a ground not pluged into anything. does anyone know where it goes. its for my s13 redtop.
also after running my car for a few minutes it stalls out and is hard to keep a good idle. currently i have no BOV and i have mounted a FMIC so should i just plug up this hole until i have a BOV and would that solve my problem? Heres some engine bay shots as well tell me if you see anything wrong this is my first swap and i wouldnt mind some criticisim. Last edited by FRoSt415; 07-24-2008 at 09:44 AM.. |
![]() Join Date: Mar 2007
Plug up that b.o.v insert it's causing major boos leak.. Bad air flow=Bad idle.. And that ground wire, there is a little metal tab right next to it on the fire wall. It plugs right on to it.
Obliterate |
![]() Join Date: Nov 2007
yea, i just wouldn't do a lot of crazy boosting if you want to save you turbo's life
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
![]() Join Date: Jan 2004
that ground is for the igntion, there is a spot for it on the fire wall under that lip in your picture.
s13 parts fs:#/f/showthread.php?t=193416 sr parts fs: #/f/showthread.php?t=193399 s14 parts fs:#/f/showthread.php?t=193420 180sx part out #/f/showthread.php?t=203711 |
If you cannot find the tab, then it must be missing. All you need to do is make your own ground from good thick copper wire to connecting point on the block to a good ground point on the chassy.
Above!!! |
HELP me Identify THIS!!!!!
ok video is to big for photbucket but i think i have it fixed thanks guys i have a new problem now. can it be my ECU i have this ECU but i dont know what the specs are on it for. i have read in the past that it is for stock sr's but an not sure. when i unplug the Air flow sensor it idles just fine at about 1,500 rpm after it warms up. can anyone help me with identifying this ecu to what specs i need to run right?
Movie of idle that i can fit it cant rev past 3k MVI_0983.flv - Video - Photobucket - Video and Image Hosting ok its the MAF i think its tuned for z32 will be getting one in a few weeks let me know if anyone has one for sale for a good price. Last edited by FRoSt415; 07-31-2008 at 05:47 PM.. |
