Old 03-29-2011, 07:03 PM   #1
vutony
vutony's Avatar
Trader Rating: (144)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 144 reviews
Arrow Ahh LOT of Performance Parts: S13 SR KA Z32 - FULL Part Out
Check out my selling Feedback or Trader Rating
Located in Garden Grove, CA. 92843.
Email - [email protected]
AIM -
audiovideocentra
So the time has come for me to let go of my 240. Here are some things I have for sale at the moment. I will update this thread frequently. If you see the item listed then its still for sale. Most parts are from my personal car which are in excellent shape. These parts are 100% authentic, I don't use ebay special or fake booty shit on my car.
Price does NOT include shipping and shipping is not free. Please add 3% for paypal. NO trades.
My other thread:
#/f/sale-items/37620...ml#post3961422
#/f/sale-items/35190...4-z32-q45.html
Electronic Related Parts
Memphis PR300.2 Power Reference Amplifier - $120
- 2 Channel 600 Max Power
- In great shape, only used for a year
More info can be found here, Memphis 16-PR300.2 (16pr3002) - 2-Channel Car Amplifier Power Amp - Sonic Electronix
door actuators (locks) - $20 (blue is new, blk is used)
S13 analog cluster harness - $25 each
(2x left)
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 03-29-2011, 07:05 PM   #2
vutony
vutony's Avatar
Engine Related Parts
S13 SR injector caps, cushion ring spacers and bolts - $30 each set of 4
i do SR wiring
Old 03-29-2011, 07:11 PM   #3
vutony
vutony's Avatar
Brakes Related Parts
350Z G35 Brembo Slotted Rotors Front Set $280 (Purchased new at FR @ $389.95 plus tax)
- In great shape with less than 2,000 miles.
- Has a minor defect from the calipers rubbing on the rotors.
- Its about 30.16mm thick, min thickness is 28.4.
- Rotors are 12.75 in diameter
Z32 Front conversion brackets to use 350Z rotors
I can get these for you if needed $100 extra. The brackets below are sold.
OEM Rear Brake Dust Shield Z32 w/ hardware - $140
- I bought this used online but it is 100% functional.
- It does have minor surface rust which can be sanded and repainted.
- The dust shield cost $100 each and doesn't include the hardware.
Z32 rear caliper bolts - $10 shipped
S14 rear brake dust shields - $10
Raybestos rear pads (about half used) - $5
i do SR wiring
Old 03-29-2011, 07:12 PM   #4
vutony
vutony's Avatar
Exterior Related Parts
Raybrig HID H1 bulbs - $20
Barely used less than an hour on triple projector silvia headlights.
S13 pignose bumper - $30
- Paint is rough but bumper is intact
S13 rear hatch bumper support - $20
i do SR wiring
Old 03-29-2011, 07:16 PM   #5
vutony
vutony's Avatar
Interior Related Parts
S13/S14 Red ball shift knob - $15
i do SR wiring
Old 03-29-2011, 07:18 PM   #6
vutony
vutony's Avatar
Drive Train Related Parts
S13 2-Way Tomei LSD - $850
- Professionally installed
- Correctly broken in
- No diff cover
- Less than 5,000 miles
S13 stock shifter - $20
i do SR wiring
Old 03-29-2011, 07:19 PM   #7
vutony
vutony's Avatar
Suspension Related Parts
Handi Foam kit - $30 ($43 @ foampower.com)
- I was going to used it for my S13 to stiffen up chassis.
S13 front spindles - $70
S13 front driver LCA - $40
I also have the passenger side, same price.
S13 rear passenger knuckle w/ energy bushings - $40
Driver is sold
i do SR wiring
Old 03-29-2011, 07:19 PM   #8
vutony
vutony's Avatar
SOLD
S13 cooling reservoir
S13 SR coil pack SS bolts
S13 dohc throttle cable
S13 DOHC Engine Harness
S13 Hatch rear trunk carpet
S13 Manual Dohc lower harness
S13 SR flywheel
SR ARP Pro flywheel bolts
S13 front 6.5 speaker conversion brackets
S13 cooling pane
Nismo "Dildo" Shift Knob
S13 MBC heat shield
Joe P manual boost controller
Bride Super Low Max Rails Type LH
Kazama drift knob
S13 Battle Version Tension Rods
Hello Kitty Horn Button
S13 glove box from LE model
SR valve cover hardware
EVO 8/9 Rear Calipers
S14/S15 Turbo Inlet & Outlet Pipes
S13 Tanabe Front and Rear Sustec Stabilizer Sway Bars
Peak Performance inner rods
3" Flex test pipe
S13 SR air idle controller
PIAA horns
RHD center console
Momo Steering Wheel Hub Adapter 1989-1998 Nissan 240SX
S13 Fujitsubo Power Getter Exhaust System
Exhaust hanger bracket
SR flywheel bolts
Nardi Deep Dish Steering Wheel 350mm Black Leather
S13 rear side marker
S13 front LCA bushings
S13 USDM Cluster w/ 240 km/h & rev's to 9,000 rpm
S13/S14 Kazama Subframe collars
S13 Nismo Power Bracesteering
Kougaku Racing SR20DET Oversized Water Pump Pulley
GTO (JDM brand) 5MM 5 Lug Spacer
S13 Hicas steering rack
S13 manual shifter inner boots and ring
S13 SR HKS Exhaust Manifold
Samco SR20DET S13/S14/S15 Silicone Upper & Lower Radiator Hoses
12volt setup w/ manual fuel cut switch
S13 Fuel pump assembly
S13/S14 Tomei Short Shifter
Bride Vios III Type G in FRP
JDM OEM S14 Kouki Fog Lights w/ wiring and relay
Steering Wheel Quick Release
Blitz Stainless Steel Downpipe S13 S14 SR20DET
Apexi SAFC
JDM Sealant from S13 Kouki tail lights
Hawk HPS rear Z32 pads
OEM Nissan Akebono Rear Brake Shoes
HKS Universal Intake
JVC KD-AV7010 DVD deck
Front 30MM Aluminum Z32 Calipers w/ hardware
A'PEXi D-Jetro Power FC for S13 SR20DET
S13/S14 Turbo Timer Harness
DSS Aluminum Driveshaft 89-94 240SX
BRAND NEW S13 SR20 Engine Harness
APEX'i Super AVCR Boost Controller
Mishimoto Aluminum Radiator
Hockey pucks
S13 Custom 3" cat back exhaust
S13 radio brackets w/ din pocket
180sx sun visors
S14 Kouki HID Retro Fit
Nissan silicone
S13 manual lower harness
S13 VIS carbon fiber hood
180SX JDM Igntion cylinder w/ original key & door locks
Nismo Wheel/Tire caps
Nismo license plate bolt cover
S13 pignose driver fender
Autometer Gauge Pod 1989-98 240SX
Prosport oil temp and pressure gauges only
Auto Meter air/fuel gauge
S14 Passenger Seat
Z32 front seal kit
OEM transmission mount
i do SR wiring
Old 04-01-2011, 07:09 AM   #9
Okinawandrifter87
Okinawandrifter87's Avatar
Headlights are sold to me! Thanks!
Driftphreak87
Old 04-01-2011, 09:15 AM   #10
socal.s13
socal.s13's Avatar
socal.s13 is an unknown quantity at this point
Damn this is alot of good shit.
FRIENDS DONT LET FRIENDS DRIVE HONDAS
socal.s13 is offline   Reply With Quote
Old 04-03-2011, 06:00 PM   #11
vutony
vutony's Avatar
Yupp, im sending it out tomorrow.
Thanks, help me out and purchase some. LOL
i do SR wiring
Old 04-04-2011, 01:44 AM   #12
ChacaSlider
ChacaSlider is an unknown quantity at this point
Still got the red ball shift knob.
ChacaSlider is offline   Reply With Quote
Old 04-04-2011, 02:02 AM   #13
ship2236
ship2236's Avatar
Trader Rating: (18)
ship2236 is making a name for him/her selfship2236 is making a name for him/her self
Feedback Score: 18 reviews
Send a message via AIM to ship2236
Damn shudder jumped on the walboro dude flaked! How much if I were to come pickup the entire piggy front and 180sx cylinder w keys setup?
ship2236 is offline   Reply With Quote
Old 04-09-2011, 11:38 AM   #14
vutony
vutony's Avatar
Yes, pm me.
Lmk if you want this still.
i do SR wiring
Old 04-09-2011, 12:10 PM   #15
Future_gohan
Future_gohan is an unknown quantity at this point
I might be interested in those 4" speakers. I'll message you
Future_gohan is offline   Reply With Quote
Old 04-11-2011, 09:08 AM   #16
nismo_nate
nismo_nate is an unknown quantity at this point
are you ever in the 626 area? i'll take the 4 channel 1000 watt amp.
nismo_nate is offline   Reply With Quote
Old 04-15-2011, 11:35 AM   #17
vutony
vutony's Avatar
Sure, keep me posted.
Sorry I dont travel there often. I can meet you in Fullerton if that helps.
i do SR wiring
Old 04-15-2011, 06:55 PM   #18
uwshbch
uwshbch is an unknown quantity at this point
Need s13 driver side power window switch 91up
pm me back or 323-241-7708 thanks
uwshbch is offline   Reply With Quote
Old 04-20-2011, 05:00 PM   #19
NAVY-ET
NAVY-ET's Avatar
NAVY-ET is an unknown quantity at this point
do you still have the 4 channel amp ?
NAVY-ET is offline   Reply With Quote
Old 04-20-2011, 05:38 PM   #20
guitargod240
guitargod240's Avatar
guitargod240 is an unknown quantity at this point
extremely interested in prosport gauges! u still have em? if so which ones r they oil press and temp? also how much to ship to 12065 if u have em? plz lol and one last thing if u have em can i c pics of them lit up or no jw how condition is. thanks man!
guitargod240 is offline   Reply With Quote
Old 04-29-2011, 12:32 PM   #21
vutony
vutony's Avatar
Sorry I dont have that.
Yes I do. PM sent.
SOLD as is, not tested. They came in a parts car I got from a trade.
i do SR wiring
Old 04-29-2011, 01:05 PM   #22
guitargod240
ok whats ur paypal ill take them both for 10 and w/e shipping is to 12065?
Old 05-02-2011, 02:26 PM   #23
g35gabby
g35gabby's Avatar
Trader Rating: (26)
g35gabby is an unknown quantity at this point
Feedback Score: 26 reviews
nismo valve stem caps and plate caps sold!
g35gabby is offline   Reply With Quote
Old 05-04-2011, 03:12 PM   #24
flatblack90
flatblack90 is an unknown quantity at this point
Autometer gauge sold to me thanks
flatblack90 is offline   Reply With Quote
Old 05-05-2011, 09:38 AM   #25
tx240ss
tx240ss is an unknown quantity at this point
blitz downpipe?
tx240ss is offline   Reply With Quote
Old 05-05-2011, 06:46 PM   #26
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
if both flca are in good shape, PM me
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 05-10-2011, 04:20 PM   #27
Imarvin240
Trader Rating: (18)
S13 front lower control arms are sold to me...thanks man!
Old 05-10-2011, 06:05 PM   #28
Canasv13667
Canasv13667 is an unknown quantity at this point
Pm me price on those z32 calipers and hardware
Canasv13667 is offline   Reply With Quote
Old 05-12-2011, 01:39 PM   #29
vutony
vutony's Avatar
Sure np
Yes and shipped
Originally Posted by tx240ss View Post
blitz downpipe?
Sold months ago, sorry.
Yes, PM me your address.
Calipers were sold months ago. I only have the ebrake dust cover and hardware. LMK
i do SR wiring
Old 05-24-2011, 01:07 PM   #30
Imarvin240
Trader Rating: (18)
hey, just wondering whats going on with the flca? i sent the money on may 9th...still havent gotten anything from you or got a message back about what the hold up is...please contact me by wednesday or i will have to contact paypal for a refund, thank you.
