Banned from the Marketplace
im not sure if im posting in the right spot if not feel free to move it bt my questions are i wanna do a custom dash with autometer gauges and not the normal cluster when ordering gauges it askes for specifics like a water temp gauge comes 2 ways 140-280 degrees or 120-240 degrees so basically im gunna put up the kinda gauges i want and the diffrent options they have for it and im gunna ask you guys to please direct me to which ones are correct
car specs first so you knw what ur dealing with 89 nissan 240sx sohc turbo after market radiator with e fan walberro? fuel pump (sorri horrable with spelling) and i live in ca gauge specs 1. Fuel level short sweep electirc a. 0 ohms empty 90 ohms full b. 240 ohms empty 33 ohms full c. 73 ohms empty 10 ohms full 2. Fuel Pressure full sweep mechanical a. 0-100psi b. 0-15psi 3.water temp comes in 2 kinds with 3 diffrent readdings full sweep mechanical a. 140 -280 degrees b. 120-240 degrees short sweep electric a. 100-250 degrees let me knw guys what you think will work for my car -jeremy |
