![]() Join Date: Jul 2008
Trader Rating: (18)
spark plugs... again
Well this all stems back about 2 months ago. My car was boggin really bad when in full boost. So I bought some new spark plugs bkr6e's or whatever and the car ran fine. Shortly afterwards I put in a manual boost controller because my avcr broke and turned the boost up to 13 lbs. Then I went out and bought some ngk bkr7i's or whatever and dedcided to put them in when I burned the 6's up. So it finally started boggin again this past week so I put in the iridiums today. Well when I took it out for a test drive it was horrible. Even worse than the first time. It runs fine when not under boost but when under full boost it's really bad. when I turn the boost down to around 7 lbs it's a little better but it still does it a little. any ideas? |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
What mods do you have? What are you using to tune? FPR? Air/Fuel Ratios? What color were the spark plugs u pulled? White? Brown? Black/Fouled?
how is the bogging cause i think my car might have the same problem. is the bogging like when your on full throttle it just stops and doesnt wanna go any furthur.
Trader Rating: (18)
i have a sr20 that i got with a greddy turbo greddy fmic, ive got an safc, koyo radiator, electronic fans. the plugs didnt look bad other than orange climbing up the white near where it says NGKR. Also yes it boggs when at full throttle. At first i thought it was a boost leak prolly through the fmic, but it's all fine. I'm pretty sure it has to be the spark plugs. oh and I have an hks turbo timer.
![]() Join Date: Nov 2006
What did you gap the plugs to?
![]() Quote:
Well, what is the gap at now?
![]() Quote:
![]() Join Date: Dec 2006
Gap the Plugs, Your probably blowing out your spark in boost
Trader Rating: (18)
well the problems gotten even worse. I took it to a friend of mine after going through 4 sets of spark plugs which blew immediately after i entered full boost. The plugs turn a deep red color immediately. Iridiums, V plugs and bkr7es, oh and bkr6es. But I never gapped any. It runs fine at idle and under low boost. But regardless of where my psi is at full boost it shits on me. My mechanic / friend thinks it's a boost leak, but I can't find it. He wants to hook it up to a ait hose and find it but he's been too busy. I checked all of my intercooler piping and I cant find a leak. When my car was running fine I never gapped the plugs either so I'm pretty stumped. How do I tinker with the cas if I should?
#17 |
Trader Rating: (18)
Nope, the guy who sold the car to me keeps tellin me not to gap them but screw that. I'll get some new ones tomorrow and gap them and tell everyone how they did. I really hope that's the case.
Trader Rating: (18)
I'm going to try gapping the first set at .028. If that doesnt work does anyone have any suggestions for a better gap. I'm runnin a red top with a greddy turbo, greddy fmic, koyo radiator and electric fans. And I like to drive at about 12-14 psi
#19 | |
Stop listening to the guy who sold you the car. oh, and check and see if your throwing any codes.
#22 | |
Do you know what your base timing is at? Honestly, you seem pretty clueless about what you have, and what your engine can/cannot do... you might want to learn a bit more about it before you go blindly turning the boost up and blowing it up, then blaming Nissan for shitty motors, when it was the owner who was being shitty. Don't be that guy. |
#23 |
Trader Rating: (18)
Ok, first of all I'm not blaming nissan for anyhting. I love my car. 2nd of all yes I'm pretty clueless but that's what 4 1/2 years in prison does to a person. Alot of time I missed out on working on cars.That's why I'm on here, because I don't know everything obviously. Obviously I bought the car with most of the work done to it. Oh and I have an SAFC unit and an HKS turbo timer not that the turbo timer would have anyhting to do with this. Does anyone know approx. which setting I should set on my SAFC?
#24 |
Trader Rating: (18)
Well I found a boost leak. There were a couple of holes in the intercooler piping where it leaves the engine bay where the battery use to sit. So we fixed it and I took it out for a run. It runs WAAAY better in first and 2nd gear. It still bogs down a little but not nearly as much. 3rd and higher gears are better but not as bad as it was. I couldnt find any other leak so I don't know if it's because I already fouled my plugs out or whatever elseit might be. I'm still wondering if it's my timing or CAS. I'm going to change my plugs again today when the rain slows down again and hopefully that does it.
#25 |
![]() Join Date: Apr 2005
if you gapped your plugs down to .025 and its still breaking up, its not the gap. that should be undersized gap for 13psi, you could probably bring it back to ~.030 and maybe bigger, safely
#29 |
Trader Rating: (18)
Here's some pics of the spark plugs
http://i302.photobucket.com/albums/n...t/DSC00984.jpg" http://i302.photobucket.com/albums/n...t/DSC00985.jpg http://i302.photobucket.com/albums/n...t/DSC00987.jpg http://i302.photobucket.com/albums/n...t/DSC00986.jpg These are only one day worth of use too. Also prior to the boost leak, but I havnt been able to get those plugs replaced yet. |
