1995 Nissan 240sx Red Top A/C
I got a 1995 Nissan 240SX with a SR20DET red top. My car is running with out a/c. What must I do/purchase to have a/c in my car?
First you need to decide if you want to get custom lines for the sr20det compressor or get a custom A/C bracket or the pathfinder comp. clutch swap. I did/recommend the codyace adapters for the ka compressor on the redtop. Other than that you need to have the Ka lines. Then wire up your a/c relay if it isn't already hooked upto the ECU.
It's not too hard you just need to search a little. There's plenty of info in the forums and download the FSM. |
