#31 | |
#33 | |
#34 |
![]() Join Date: Mar 2008
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Did u check to see if your ecu is getting 12 volts to pin number 34???? that was my problem the whole time!!!! and i blow my money on coolant temp sensors tps sensors mising with the tune, u name it!!!!! and the whole time it was the wiring!!
#35 |
Does anyone know what I should look for for a s14 sr20 in a '97 240? I am having this exact problem as OP
edit: looks like this start signal is Orange on 97 240 so if that connects to pin 43 for s14 sr ecu, then it should work the same? How does the car start without the ecu getting this signal in the first place? Last edited by obsolete; 11-19-2010 at 10:02 AM.. |
#37 |
![]() Join Date: Dec 2009
Sorry for bumping such a old thread but could you just cut the orange wire at the ecu then run a wire from ignition "start" wire directly to the orange wire or even just splice a wire into the orange wire without cutting it or would this interfere with the tach?I had cut and redid my starter wiring and now have this cold start issue.
#39 |
In that case all that needs to be done for s13 sr20det is wire a wire directly to starter ignition switch the wire that's on the starter that connects from ignition switch that's only live when turning the switch to start "cranking" from the new wire you wired to this goes directly to ecu pin 34
Its a orange wire with silver stripe but don't confuse it with boost solenoid wire directly opposite from it as its orange as well.look up pinout to be sure.anyways the reason we wire this to ingition wire is this tells the computer you are starting the engine and therefore compensates by spraying all 4 injectors while it cranks which fires up engine faster.BTW I did accidentally wire up to orange boost solenoid by accident and no damage happened just to let you know,but when I wired to the correct orange wire she fires up instantly.I did not cut orange wire I just spliced into the wire and alls good. |
