![]() Join Date: Jul 2009
![]() Feedback Score: 27 reviews
Godspeed Project s13 S14 steering angle adaptor!!!
These are going for: $35 picked up or $40 Shipped (California customers please add 9.25% to shipped price for shipping cost.) Now in stock is the S13 / S14 Steering Angle Adapter. Comes with: (1) Steering Angle Adapter & (1) 7mm spacer (Optional for bit more angle) Below is the specifications when used with the spacer: GODSPEED steering angle adaptor will allow your steering angle from 38 degree (oem) to 52 degree (gsp adaptor). That is a total of 14 degree gain over stock. Simply install the adapter on the passenger side of the steering rack and re-center the rack after install. That's it! (See pictures below for example) OEM vs. Godspeed Project Leading wheel: OEM is 38 degrees vs. Godspeed is 52 degrees Trailing wheel: OEM is 30 degrees vs. Godspeed is 39 degrees Turning circle (curb-to-curb): OEM is 30 feet vs. Godspeed is 24 feet Lock-to-Lock: OEM is 3 turns vs. Godspeed is 2.8 turns Angle after adapter installed:
Godspeed Project 2518 Continental Ave El Monte CA 91733 P: 626-442-3988 W:godspeedproject.com www.facebook.com/godspeedproject |
