![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
GKTech - Axle Spacers 3x2/5x1/6x1
3x2 10mm Axle Spacers (pair)
The GKTECH axle spacers are CNC machined from billet aluminium and are concentric in design to ensure the perfect fit (critical due to the load put through spacers). When running extended LCA's, S14/S15 subframe in an S13 or running bolt on dual caliper brake kits the axle is moved further out and as such is prone to breaking. Please check under your car before ordering to see if you have 3x2, 5x1 or 6x1 axles. There doesn't seem to be any consistency across the Nissan range so check for yourself. Includes longer Grade 10.9 bolts Vehicle Compatibility: - Nissan 180sx - Nissan S13 Silvia - Nissan S14 200SX - Nissan S15 200SX - Nissan Skyline R32 GTS-T - Nissan Skyline R32 GTR - Nissan Skyline R33 GTS-T - Nissan Skyline R33 GTR - Nissan Skyline R34 GTT - Nissan Skyline R34 GTR - Nissan C33 - Nissan C34 - Nissan C35 - Nissan A31 Cefiro - Nissan Z32 300zx Price: 79 AUD (approx. 68 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of August. ORDER HERE: http://www.gktech.com/index.php/3x2-...acer-pair.html 3x2 15mm Axle Spacers (pair) Price: 89 AUD (approx. 76 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of August. ORDER HERE: http://www.gktech.com/index.php/3x2-...acer-pair.html 5x1 10mm Axle Spacers (pair) Price: 79 AUD (approx. 68 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of August. ORDER HERE: http://www.gktech.com/index.php/5x1-...acer-pair.html 5x1 15mm Axle Spacers (pair) Price: 89 AUD (approx. 76 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of August. ORDER HERE: http://www.gktech.com/index.php/5x1-...acer-pair.html 6x1 10mm Axle Spacers (pair) Price: 79 AUD (approx. 68 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of August. ORDER HERE: http://www.gktech.com/index.php/6x1-...acer-pair.html 6x1 15mm Axle Spacers (pair) Price: 89 AUD (approx. 76 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of August. ORDER HERE: http://www.gktech.com/index.php/6x1-...acer-pair.html FAQ Will these fit my car? Your best bet is to jump under the rear of your car and check what PCD you're running; 5x1, 6x1, or 3x2. Do you make these in other PCD's or widths? We're not making these in any other PCD's at this stage. We're only currently making the axle spacers in 10mm or 15mm. Do I need these? If you are moving your hub out for any of the following reasons: running a dual caliper bracket, you're running extended LCA's or you're running an S14/S15 subframe in your S13. Ideally the amount that you're spacing out your hub, you want to space out your drive shafts. For any inquiries please e-mail us at [email protected]. Last edited by GKTECH; 08-05-2014 at 02:54 AM.. |
![]() Join Date: Jun 2007
what happens if someone is running an s14 subframe in an s13, has dual caliper brackets, and has extended rlca?
cuz u know, more trackwidth is better, and that's just awesome!
Not sure how much would that add up to, but you should definitely go with the 15 mm spacers. The ones listed here are the only spacers we are currently manufacturing.
