Old 01-27-2012, 08:18 PM   #1
soryu
soryu's Avatar
soryu is an unknown quantity at this point
clean cluster. check engine,gas lights
so the check engine light was on in my cluster.
took out the cluster cleaned it up there was some dust build up inside.
i also took out the bulbs removed the little blue caps on the bulbs put everything back and now the check engine light is gone.
has this happened to anyone?
i haven't gotten the cars ecu checked out yet.
also the gas light come on when nearing empty. but it comes on dim then it gets brighter the more i drive. but i doesn't get as bright as the the lights on the right side of the cluster.
is this normal on the s13.? or are there some electrical issues?
soryu is offline   Reply With Quote
