Sup guys!
I was woundering what do i realy need for a sr. The only thing im sure about is the rocker arm stopper. What else do i hava to get? I want it as reliable as possible and wanna avoid dumb problem. |
#2 | |
![]() Join Date: Aug 2014
![]() Just get a 150 shot of nitrous and be done with it lmao |
![]() Join Date: May 2011
Im going to be nice because this seems to be your very first post on zilvia
you don't need anything for a sr20, they have this nifty thing where they are turbo from the factory and as such are fairly tough in stock form now the question that needs asked is what are your plans for this engine and car? for road racing and autox you wont need anything, for drifting and bouncing limiter rocker stoppers are nice to have but aren't really needed, get some small diameter intercooler piping, a wideband, a boost gauge and learn the car before making changes to anything this is the only chance you get at someone here being nice, don't squander it |
Don't get rocker arm stoppers, they do more harm than good.
You want reliable? Leave it stock.
MRP Manufacturing |
Keeping it stock, on stock ECU requires nothing much besides a wiring harness.
My vote: Gasket kit MLS H.G. (Cosworth IMO) ARP head studs T28 (not some POS ebay turbski) CodyAce manifold with Tial 38mm External W.G. JWT S4 cams 850cc inj. AEM ECU (Soft fuel cut, no fire balls, but no rockers exploding) 3" exhaust FMIC Boost controller Scope the "GTX2867 thread" for proof of 400 WHP. (T2 turbo stuff) I think the general consensus about SRs, is once you go T3 turbo, it's going to be unreliable. (without loads of cash) |
Truth, bent valves are more expensive than thrown rockers
![]() Join Date: Sep 2005
No it's not! The consensus when going T3, is it better make 500hp plus! If not everyone is clowning you behind your back!
Probably, but it's true.
![]() LoverTechnologies "Half Broken Things!" Last edited by cotbu; 09-12-2016 at 07:30 AM.. Reason: You probably meant that for Jorgs_7? In that case it's not true! |
| 240sx, build, drift, problem, sr20det |
