S14 Suspension problems
Hi guys having crazy bump steer issues or what i think is bump steer. i have full adjustable multilink suspension in front but stock rear suspension, as well as stock struts. The car was aligned and now having this issue. I do have the outer tie rod shims on the tie rod but im at stock height could that be causing it ? The guy doing my alignment said he couldnt get the camber in spec because i dont have coilovers with adjustable top hats, so there is a 1 positive degree or two on both sides. Please shed some light.
