![]() Join Date: Apr 2011
Thanks for any help in advance!
I have a '93 240sx, I swapped a RB20 engine in. New Engine harness/coil pack harness, ignitor, Cam angle sensor. Engine has spark and good fuel pressure but fuel injectors don't seem to be spraying. Injectors are getting power though Any clues as to what can be causing them not to spray fuel? |
I assume this car was running before the swap? What about after? Otherwise make sure your fuel pump is working. (You should hear a hum when you turn the key to the on position)
You can also try cranking, then pull a spark plug out to see if it is dry, this will confirm no injector fire. Or pull the fuel rail off and have it spray onto a piece of cardboard or towels when you crank the engine to confirm no injector fire. Assuming you have no injector fire, I would point to the 2 relays near the ECU that you should have. One is for your ECCS and the other for your Fuel if I remember correctly. From the sound of it you probably at least have one. If you have both, try swapping them to see if you get injector fire. This is most likely your issue. Quoting research I just did, any green Nissan relay should work. It is the same relay that is in your Engine bay fuse box. |
I have a Wiring Specialties harness so it has different fuses but those are working, my fuel pump does prime when I open the switch. I pulled out my fuel rail and it isn't spraying fuel from injectors. |
Did you ever get this figured out?
I would look for ECU diagnostic codes. Also you wouldn't have happened to buy this swap from a third party(not an importer) or the ECU seperate? I would imagine that an automatic trans ECU wouldn't pump fuel if it didn't receive the right signal... You can check if you have the right ECU with this list. Skyline ECU Serial Numbers(how to know which ecu you have) - Nissan 240SX Forums |
pull the cas out, remove fuel pump fuse
turn it by hand with the key at "on" position you should hear each injector click and have spark on each coil if not cas maybe bad also make sure all your engine grounds are good |
My old RB would crank, fire, and die after one second of running. I could hear the coils fire when I spun the CAS. But injectors would not fire. What I found was corrosion in the ground distribution block in the harness. Usually located near the ECU. Its a large black connector that looks like it doesn't connect to anything and may be covered in tape. Don't remember how many pins there are, as it's been a few years for me since I had this issue. Anyways, take this apart with a small screw driver. You will see there is now a male and female part to this. Clean corrosion out and plug it back in, and hopefully this will help start your car.
RB20 DASH PLUG
BLACK/PINK-------------------- FUEL PUMP YELLOW/RED------------------ TACH SIGNAL YELLOW/GREEN-------------- VEHICLE SPEED SENSOR BLACK/YELLOW-------------- IGNITION START SIGNAL ORANGE/BLACK-------------- CHECK ENGINE LIGHT TEAL----------------------------- AC RELAY TEAL/RED---------------------- AC SWITCH *NOTE*------ FSM states PIN #32/Check engine light as PINK/BLACK But mine was ORANGE/BLACK S13 WIRE/RB20 WIRE SOLID/STRIPE DASH PLUG WIRING YELLOW/RED------------------- TACH SIGNAL------------------ YELLOW/RED YELLOW/GREEN--------------- SPEED SIGNAL----------------- YELLOW/GREEN ORANGE-------------------------- IGNITION START-------------- BLACK/YELLOW *NOTE* The BLACK/YELLOW wire should trace back to PIN #43, which you might have read about on the other guides. BLACK/PINK---------------------FUEL PUMP---------------------- BLACK/PINK S13 wire found on the BROWN plug. RB20 wire found on the DASH PLUG. I actually extended the wire from the dash plug to the brown to make sure it would reach and plug in. RED------------------------------ CHECK ENGINE LIGHT-------------- ORANGE/BLACK BLACK---------------------------- GROUND
![]() 95 240sx RB20 415whp 91 Nx2000 VVL yo |
| rb20, swap |
