| Businesses Review your dealings with commercial entities here. Remember: Fair and objective. Flaming, accusations, and complaints are not allowed. Zilvia is not a grievance forum. |
![]() Join Date: Jan 2009
Circuit Sports S14 Zenki Tail Lights
First off, Not sure where to put this, but I know a lot of vendors sell this product and I just received it (until I resolve this QA issue I will hold off on vendor review, so far everything is going smooth).
Circuit Sports = No Product: Circuit Sports NS1493-RTL02C-JY Crystal Rear LED Tail Lamp Lights S14 240SX Zenki ![]() More Photos imgur: the simple image sharer The actual product is cheaply made, and it shows. The red in the tail light is not even actually red, but it's a piece of adhesive/sticker vinyl stuck in a clear plastic light, then laid across to emulate the 'red'. Also, there is a wrinkle in the actual tail light adhesive as seen in the photos. There was also a crack, which I believe came from factory not the shipper. I highly recommend you stay away from this product, as it is a waste of time. I'm lucky enough to even get some sort of resolution on it. You might not be so lucky. Thanks and good luck.
