Odd cluster issues... help
Ok, so let me start from the beginning to get all the info out there. I pulled my SR out of my old car that was running with no issues and swapped it into a better shell. I fixed everything that I saw issues with as we did the swap, but I'm having a weird issue with the cluster now...
When I'm driving, if I hit a small bump, the tach will drop out for a split second. If I hit a larger bump, the tach and speedo will both drop out for a split second and everything on the dash will act as though I shut the car down, meaning the seatbelt dinger will kick on, occasionally I'll even get a phantom wiper sweep. Also, occasionally when driving at WOT, I'll get above 4k and the tach and temp gauge will shoot up, but they return to normal as soon as I get out of the throttle.
I don't feel any issues with engine (ie. I don't feel any power loss when the drop outs occur). I've checked everything I can think of... Main powers seem solid, all grounds look good. I'm going to try swapping the cluster this weekend, can you guys think of anything else?
