AC on all the time!?!?
Just recently my s14 started having problems with the a/c. Well not the a/c but the fan would turn on when the car was even if the knob was set to off. I just can't turn it off anymore. Anyone have any solutions to this problem if it's happened to you?
#2 | |
Are you trying to say on or off here "the fan would turn on when the car was ___ even if the knob..."
I haven't heard of this happening when the ignition is set to off, but it sounds like you definately have some wiring issues. Quote:
FEB.06.2005 |
try swapping out the push control unit with a working one, could be the internal switch contacts ( i doubt two wires would strip there sheathing and splice themselfs together)
Ok so my question was poorly written. I was trying to say that everytime I turned my car on my fan would turn on to almost full blast even if the knob was set to the off position. Thanks for the replies though! Sometimes I hit a bump and it'll turn off for a couple of seconds but then turn right back on.
