![]() Join Date: Feb 2010
TT 300zx engine leak.... coolant
Engine seems to be leaking at the rear passenger side. I was thinking it could be a heater hose.. Anything else back there that could be causing this leak.
83 Views.. and NO INput? LoL.. come on guys? the engine bay is soo cramped i cant tell where its coming from... its right underneath the turbo ... so i guessed it might have a coolant leak? is this possible..lol Help..ive been researching.. No Luck
honestly its a random leak... sometimes it leaks allot... Clear... sometimes it doesnt leak at all... Doubt its AC.. mine doesnt work... i was thinking it could be the Turbo...
its not black.. kinda semi Green/ clear
Second if the level is down go to ur local auto parts store and buy a pressure tester or borrow one from a buddy at a shop.. Best way to tell where the leak is if it is the coolant
yeah no coolant leak... im not that bad at diagnosing cars.. I usually know what to check.. But i am stumped on this one..
the radiator doesnt drain. There is a leak (sometimes) i was thinking its leaking from the TURBO, let me take some pictures.. I might just have to remove the plenum and take a better look.. the TT Z has a very tight engine bay.. -_-
