Barrys World
You comment on the "ricer" gauges when you got the car, and then bought gauges? Lol looks like a good build, youll have fun with the 2JZ. What are you doing to engine as far as mods go?
#9 | |
Rebuilt bottom and top end, with Bc 264s cams. Would like to buy some HKS Cam gears when I get around to it. |
Barrys World
Sounds good, thats what Im boutta do to mine soon. What paint did you use for the engine?
#17 |
#20 |
![]() Join Date: Jan 2003
Trader Rating: (43)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 43 reviews
^^^ u should start making rad hoses and heater hoses just for the s13/s14 2jzgte swapped man!! I think their is a market for it
fdrea |
#21 |
#23 | |
![]() Thanks
Mishimoto Automotive |
#27 |
That wiring looked pretty intense. How involved is it? I'm thinking of doing one myself. I might go with the zero lab kit which includes driveshaft engine and tranny mounts. I will have to deal with exhaust fab wiring and fuel lines correct. Anything else super involved?
#28 |
Thought I would put down a fast list of the things on the 240
Engine -Stock 2JZ-GTE Engine -Walbro 400 fuel pump -Mr2 turbo radiator (With Turbo Samco Hose's) -Dual Flex-A-Lite electric fans -Dif Dual fan Controller -Serpentin belt (With AC) -HKS Timing belt -Wireharness Mod -Aem Ems V1 -New 240sx Motor Mount's -2jzgte mod Motor mount's -Clevite Bearing Kit -Engine Rebuild (With Thermostat, oil filter, with Royal Purple) -Light Weight Pulley's -Hks Racing Hi-Power (75mm) -Custom downpipe with Mid pipe -Fuel line's, with all the Fitting, 2 Inline filters, (ETC) -Front Sump Oil pan Setup -Greddy Intake Manifold (Gasket's, etc) -2jzgte Igniter -Fuel Injecter Clinic Rail -Oil Catch Can -Relocation Battery box (2g wire, etc) (With Optimal Battery) -Band new Belt Tensioner -BAND NEW USDM Waterpump -FRP Fuel Gauge -FRPer Turbo Setup -Mishimoto Intercooler 31x12x4 -Oil Feed Line's For Single turbo Kit -3 inch Intercooler Piping (Custom) -XS Manifold T4 Turbo (Gasket's, etc) -BW Turbo S3 -44mm Tial wastegate (purple) -Tial BOV (Purple) -4Inch Intake Pipe -4 bolt to v-band adapter -wastegate DumpTube Driveline -R154 Tranny (With BAND NEW REBUILD) 0 MILE"S (5 Speed) -LightWeight Flywheel (11.5 LBS) -1jz bellhousing (With Bolt's) -V3 short throw shifter -Custom Driveshaft -300zx TT left Side Axle -q45 right Side Axle -Q45 Differential LSD -All poly subframe bushings (Energysuspension) -Sikky front Sway bar -Shifter Extension -Act 7m/1jz Clutch -New Clutch Slave -2jz Clutch line Suspension/wheels -BC Coilover's -300zx TT Big Brake's (Front and Rear) -300zx E-brake Assembly -R33 E-brake cable's -Drilled/Slotted Rotor's (Front and Rear) -Band new 300zx Rear hub's -Strut bars front and rear Interior/sound: -Cage -Defi Oil Pressure gauge (52mm) -AEM Boost Controller gauge (52mm) -Defi WaterTemp gauge (60mm) -Defi Oil Temp gauge (60mm) -Gauge Pod's (2) 52mm -Custom Door Gauge Pod's (2) 60mm -Dak (Tachometer) -Dak (Speedmeter) Exterior: -HID Kit low Beam's (10k) -s14 Fog Light's -New Front new ( Hood,Fender's,Front Bumper) -New Trunk Lid -Navan grill -New comer light's -headlight's -Rear and Front Lip's |
#29 | |
#30 |
Its on the road, oh no..
Taking for Tune, Then body work is next ![]() The rear set of tires are for sell (Like Band New!) Maby 300 miles, No burn outs done with them. Here's Link...#/f/wheels-tires/485...760-sport.html |
