Sr20 Rebuild
Hey Guys,
I have a engine build up list for all of you's to ee what u guys think. O and if u guys can think of some parts to add plz help out... i onli got 2gz on interior motor for a rebuild..... suspensions and so on for later - Greddy Head Gasket (1.2MM Metal) , or Power Enterprise 1.5MM, 1.8MM Metal) - Greddy or HKS Valve Springs Sets ?? - Greddy or HKS Arm Stoppers ?? - HKS CAM SHAFT (Intake and Exhaust) - HKS Cam Gears... 265??? or More?? - Pistons??? i dunnoz still thinkin.... Cost too much.. - Nismo Thermostat and what power will it add up after everything is in, basicly have a few month to wait before actually purchasing.... Thanks Mark |
apexi head gasket, what stage cams do you want? if stage one you'll be fine with the stock valvetrain. RAS are good security. The thermostat came out of nowhere, it should just be done as maintenance, OEM one works fine, i have the Nismo one myself...
From the looks of your post, do more research and SEARCH. There has been many reviews on different products. |
