Old 05-13-2008, 03:04 PM   #1
theyellownerd
theyellownerd's Avatar
theyellownerd has a spectacular aura abouttheyellownerd has a spectacular aura abouttheyellownerd has a spectacular aura abouttheyellownerd has a spectacular aura abouttheyellownerd has a spectacular aura abouttheyellownerd has a spectacular aura about
26dett prob
had an rb26 installed into my car... wiring..good vacuum... so so... fixed most of the problems... but still have a bad idle and will die when letting off the throttle... narrowed it down to the fact that it turns out we have after market injectors without any air/fuel management system to correct the balance and it is running way too rich. so i bought and correctly installed the new afc neo and have the initial set up complete... after getting into the system, i realized that my knowledge has reached its peak and do not know where to go from here. if anyone has any suggestions, ie: how to do a basic setting on the neo, or get my car running better (lol), i am all ears. also, it is running worse since the neo is in, obviously because it has no settings on it yet. thank you for your time. socal people willing to help!! lol
[email protected]
theyellownerd is offline   Reply With Quote
Old 05-13-2008, 03:09 PM   #2
((sr)) kelly
((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute
you need to go into the high/low throttle settings..you can reach your fuel trims there... since you have no idea what size the injectors are, start leaning it out in small increments. id say 5% at a time....keep drawing the fuel down till it idles fine... do you have a wideband? If you are going to blind tune it, then get it streetable, and baby it to a tuner.
just draw the fuel down from as low as you can go to about 3000 rpms. so you can limp to a tuner
((sr)) kelly is offline   Reply With Quote
Old 05-13-2008, 03:26 PM   #3
theyellownerd
they are purple injectors and everything ive read so far has led me to believe they are in the 550 to 600 range... does that info make a difference? lol
Old 05-13-2008, 03:30 PM   #4
Erjay1
Erjay1's Avatar
Erjay1 is making a name for him/her selfErjay1 is making a name for him/her self
Best thing to do will probably be to take it or tow it to a tuner. I'd be really pissed if I killed my RB26. Post pics.
Erjay1 is offline   Reply With Quote
Old 05-13-2008, 05:21 PM   #5
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
First of all Pics or i Vote BS. I have yet to meet an RB26 owner that is this big of a noobie. also the pics better have your Screen name on a piece of paper sitting on the valve covers with a current date.
-Juan
Review Thread
bardabe is offline   Reply With Quote
Old 05-13-2008, 07:56 PM   #6
theyellownerd
dont need to prove to no one but my friends and family... i didnt come on here to brag... i came to get technical advice and if you dont have any... then vote bs, it doesnt matter... and for erjay.. i will post pics as soon as i figure out how to get them off my new phone.. lol
-Juan
Old 05-13-2008, 08:44 PM   #7
theyellownerd
more to come
Old 05-13-2008, 09:52 PM   #8
theyellownerd
Old 05-13-2008, 09:58 PM   #9
theyellownerd
as an update... went to my car today and wanted to fire it up... just turning over and over again.... pulled out a spark plug... FOULED! bad... these are brand new (two weeks) and this is the second time i had to clean it... put it back in and what do you know, it started up... now to work on the idling problem again right? nope... after it killed itself... trying to restart was a joke... its all fouled up again.. too much fuel in there... but i dont know why it is so rich.... maybe i should get an adjustable fuel reg?
Old 05-13-2008, 10:00 PM   #10
renegade_ewok
renegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to behold
That would probably be a step in the right direction. You are running an aftermarket fuel pump on original fuel regulator?
renegade_ewok is offline   Reply With Quote
Old 05-13-2008, 10:07 PM   #11
LongGrain
LongGrain's Avatar
you have big injectors and you dont know why its running rich?
the simplest solution would be to get some stock injectors...
LongGrain is offline   Reply With Quote
Old 05-14-2008, 12:31 AM   #12
theyellownerd
Originally Posted by LongGrain View Post
you have big injectors and you dont know why its running lean?
is that a serious question?
did i ask why it was running lean?
stock injectors are not cheap nor can i just go and pick them up... and why wouldnt i tune up to the injectors rather than tune down my car?
for the rest who read this post... please offer reasonable and logical solutions to THE QUESTIONS I ASKED.... how to use, map out and tune the safc neo... and also if my fpr is bad?
Old 05-14-2008, 02:45 AM   #13
coreansurfer
coreansurfer's Avatar
coreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfectioncoreansurfer is close to perfection
bring your car to us, we do all kinds of rb swaps.
we can make it work.
Originally Posted by avs0730 View Post
if I stupid why is people pm about the car
coreansurfer is offline   Reply With Quote
Old 05-14-2008, 03:21 AM   #14
OMGYO
OMGYO's Avatar
OMGYO will become famous soon enoughOMGYO will become famous soon enoughOMGYO will become famous soon enough
after larger injectors you should get a tune to correct the fuel map
http://forums.hybridz.org/showthread.php?t=87580 check this out...it might help u
WTF!
OMGYO is offline   Reply With Quote
Old 05-14-2008, 03:43 AM   #15
Nismoknightska-t
Location: Azusa, socal baby! why do i live this way?? it must be the money!
Nismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfectionNismoknightska-t is close to perfection
Send a message via AIM to Nismoknightska-t
dude... you live in socal.. tow it to one of the 34234234 local shops that can tune and its done.. simple..
NismoKnights
Terrorizing Honda crews since 2003
ls2 powered kouki..all show and GO! putting it down on the streets and the track! LMAO V8
Nismokights on http://www.youtube.com/user/NismoKnights
Nismoknightska-t is offline   Reply With Quote
Old 05-14-2008, 06:16 AM   #16
posdrift240
posdrift240's Avatar
posdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymore
Well my Rb25 kinda has the same problem, Sometimes. Mostly when it warms up.
First off get a aftermarket Fuel pressure regulator so you can make sure the injectors are not getting a ton of fuel from the pump.
2nd, Check your timing. My 25 Stock ECU likes to secretly take timing out and will cause the car to stall and also run rich!!
3rd get a wideband 02, This will be a very good tuning tool.
4th, what plugs are you trying to run? if NGK, Throw them away, My RB Hates them. I Crossed mine over to a AcDelco and have not fouled a plug again.
5th, You can adjust the AFC fuel maps to lean it out. With the wideband 02 you can read the air/fuel mixture and make sure its correct without taking it to a tuner.
6th, Zilvia Blows when it comes to RB knowledge, There just a bunch of Rich Kids Who Daddy buys them toys to run there mouth about. If you want Real RB help the RB forum on NICO is your best friend, Really cool and knowledgeable guys over there.
posdrift240 is offline   Reply With Quote
Old 05-14-2008, 07:18 AM   #17
((sr)) kelly
i told you man.. draw down your fuel % throught the fuel trims...
ill sell you some stock GTR injectors if you want.. just drop them right in and fire it up
Old 05-14-2008, 09:01 AM   #18
Blown240sx
Blown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymore
Do you know who makes ACDelco? NGK.... Sounds to me you wernt using the right plug.
If you think they are 550 or 600 do this. 444cc/550cc x 100 = 80% so you need to lower the map by 20% on the low throttle settings. Leaning it out to much at idle will not hurt the motor since there is no load. Worst case it will just shut off or miss. Try setting the low throttle settings on the SAFC to -20% from 800-1600rpms and see if it will idle.
PS if your going for power the SAFC isnt the right path. Get a Power FC to make power.
I am the Negative Rep Master
Blown240sx is offline   Reply With Quote
Old 05-14-2008, 10:57 AM   #19
Erjay1
Erjay1's Avatar
Thats badass! Where in SoCal are you? I'd like to check this out sometime.
Old 05-14-2008, 04:33 PM   #20
theyellownerd
thanks man... went there today.. talked to Linh... good guy. saw what you guys have in your shop and it seems promising. i will be bringing the car by tomorrow... again thanks.
brandon
Old 05-14-2008, 05:04 PM   #21
coreansurfer
np man post up when it all works out.
Old 05-16-2008, 11:06 AM   #22
theyellownerd
should be getting some kind of word on it today... thanks everyone for the advice... for those who suggested a wideband... i hope to be getting one soon so that i can learn to use it myself. when i get it all good and running though i will gladly post better pics... again with my phone though.. lol.. thanks everyone for the support
Old 05-17-2008, 05:47 PM   #23
theyellownerd
ok... engine is running smooth.. took it home today.... but theres a new problem... i need a new tranny. other shop left the rb26 tranny in and said they fixed the awd situation... when in fact they just plugged the hole in the transfer.... so i need an rb25det tranny... anyone selling one? seems they are harder to find than i thought...(after an hour of searching) .... but if anyone has any inexpensive leads.. send them this way... until then.... ill be searching away... thanks all...
Old 05-17-2008, 05:55 PM   #24
coreansurfer
linh might have one, hit him up.
Old 05-17-2008, 06:03 PM   #25
theyellownerd
lol.. asked him.. he doesnt have one for sale.... but he did have one but it has a home already.... so the search continues! haha
Old 05-18-2008, 05:14 PM   #26
Blown240sx
Remove the transfer gear from the case. Cut off the housing and weld it shut. RB26 tranny wa-la
Old 05-18-2008, 07:08 PM   #27
theyellownerd
wouldn't the gear in the tranny that runs the chain to the transfer still be spinning as if it were doing the same job? it seems id still have a transmission that thinks its running awd... would i have to weld that gear?
Old 05-18-2008, 09:26 PM   #28
Blown240sx
Why? If its just free spinning with no resistance what will it do? The transmission will still work regardless if the font axles are there or not so how would it be any different?
You dont have the AWD brain anyway? Does it even have the AWD brain on your version RB26?
Old 05-19-2008, 07:56 PM   #29
TURBI
TURBI's Avatar
TURBI is an unknown quantity at this point
mckinneymotorsports.com sells a rb25 tranny...I think they have 1 left
TURBI is offline   Reply With Quote
Old 05-20-2008, 02:48 PM   #30
theyellownerd
nah they are out... but i think ima go with the z32 tranny... supposed to be really reliable... says mckinney and jer
