![]() Join Date: Jun 2010
j30 rear sway into s13
i have searched this site and google and can not find a deffinative answer. Does a j30 rear sway bar fit into a stock rear subframed s13? i know it will fit with a s14 subframe. but im runnin the stock subframe. the reason i need it is im going fuel cell and need a double hump sway bar to clear my dual exhaust. (ls1 swapped)
so if anyone HAS DONE this to there car chime in. not 'IIRC' need to know before i hit the pick n pull |
![]() Join Date: Sep 2006
i googled "j30 rear sway bar s13 "
1st result was: "Oem swaybar upgrades? (s13)" Oem swaybar upgrades? (s13) - Nissan Road Racing Forums 13th poster said he runs the j30 on his s13 read about it there. it also lead me to: OEM Sway Bar Interchangeability OEM Sway Bar Interchangeability - Nissan 240SX Forums |
yes but if you read his 13th post he says the line right up on his S14 SUBFRAME. i have read that thread. hence meaning he has an s14 swapped subframe, or so thats how i read it. thats why im still confused. and the second link you posted say confirmed by Def, the same guy who made that first post who only states "lined right up into s14 subframe"
but thanks for helps so far |
yeah i read that part about him saying s14 frame, but read he has an s13 so i was somewhat confused as well. i personally dont know but im bored so tried to help
