Need help with 02 sensor.
Hey I ordered an 02 sensor from Advanced Auto using the part number S13 SR20DET REDTOP: 22690-19P20 ('87 280ZX). I found that part number in the SR20DET FAQ thread. Well the one I got has a shorter wire that the one in the car, as well as the threads are a lot smaller. Here is a pic of them both.
Did the auto parts store give me the wrong one? |
![]() Join Date: Jul 2005
That said, you can remove that adapter and use a standard $5 O2 sensor from anywhere. Even a 1-wire from a random box will work at pep boys or wherever will work fine. Just find the single signal wire and connect that to the single wire. I do it all the time... Walk into pep boys and ask to look at their O2 sensors. Start from one side and keep checking boxes till you find a few 1-wire sensors. Buy the cheapest one. |
Ive used the fat-typical sensor on the redtop before. And verified that it was working with a gauge. So, no. The only thing specific about it is the size to fit the hole. And it looks like you are using an adapter. So, delete the adapter, and use a regular size o2 sensor.
