![]() Join Date: Jun 2008
drift car build
im david i work on this car, eh, kinda daily/weekly, im dedicated to drifting and thats all this car is ment to do, expect updates periodically
1984 datsun 200sx 1990 240sx ka24 swap im 18 all my work $1000ish spent on car and swap combined Drivetrain: h190 solid rear axle bitches! ka24 transmission custom poly trans mount to use ka trans welded differential newish replacement clutch haha frankinstein s13/s12 driveshaft combo suspension: rear billstein shocks, home made seperated coilover using random coil springs, and metal tubing s13 coils s13 knuckles s13 balljoints modded s13 tie rods engine: KA24E swap with 130 k miles previously auto now manual random cold air intake with k n filter shoots through car under the battery tray home made 2.5/3 inch exaust to HKS muffler removal of lots of egr crap replaced rear main seal and other small gaskets e fan jumper harness for ca20e to ka24e interior: wheel off a boat. but im going to be cool and say its some $$ brand tach i got for cheap since my stock one doesnt function unknown hub brand momo seat 4 point sparco harness fresh new automotive home-made carpet rear is stripped, and lined, battery relocated to rear new oem headliner from california parts dealer new oem door panels from dealer home made rear strut tower bar out of gas piping fully professionally dyed black interior, the dash, all the plastic switch board for hard line pump/e fan exterior: 200sx SE front lip 2 riken mesh wheels 4 jdm hoshino impul G5 wheels, super rare, over 30 years old, used in ae86 n2 compeitions in the late 70's mk2 turbo hood added a mk2 wing heres my homemade suspension idea for the rear since i cant really find anything aftermarket for the car heres the s13 suspension conversion going into the front, before next event on the 20th megan s13 coils q45 brakes s13 tension rods s13 lca s13 tie rods s13 spindle/hub heres it when i got it non running with the stock engine some progress pics i moved got a engine for 40 bux off a friend home made trans mount for the new trans cut shifter hole cause the trans is longer finished the drive train installed engine moved, AGAIN! my old s12 was clean until i hit about 6 walls sold it for 600 2 weeks ago then, got some coilovers and started my s13 swap i have q45 brakes but they dont clear my wheels i need a spacer, for now im using just s13 ones s13 ball joints got a disk brake setup from a nissan s110 (older 200sx) started putting the suspension together rethreaded and cut my tie rods to remove my toe in |
thanks, it was all pretty clean till i started drifting, the ka is getting old and nasty, and shit breaks, i keep replacing it
its only been like 4 events but tis time for SR or CA18 heres the damages from last event (hyperfest) more dirt, more grime, its funny how fast all this shit collects from drifting, but i like breaking shit it gives me something to do pulled my driveshaft to find this out, THATS why my shit was clanking around halfway throught he day, some scrap metal got caught and messed it all dyed my head, tapped valve cover nuts, i had stripped valve cover holes before, most reason to why i probally was leaking oil u can see some of the leak onto the mani here heres my crushed power steering line haha, i dunno how it broke loose and got under the member check out my oil pan clearence! i love how it doesnt drop past the crossmember more wires i gotta cut and remove lol. started taking the h165 axle apart (disk brake conversion) its not really common to find these disks so i dont have much info on the writeup i could possibly swap those axles and bolt them into my other solid axle but im not sure if A my h190 diff has the same spleen gear as the h165 axles and B im not sure how much weaker the h165 axles are... because the h190 differential on my car is rated at a silly 285 tq possibly the h165 axles could be even more weak, and i dont want that shitt if i had a god damn irs s12... aka any other year then 1984, id have disks, and a r180 good for liike 300+ tq |
#11 | |
with the megans up front, but i need to redo my rear and get lower with more stiff springs, otherr then drifting drag style, ive gotten rid of most of the roll, it was very bad stock from last weekend |
dropped the rear another inch, i might raise the front a tad and add a 8 mill spacer
im buying 2 rear 20 mill spacers so work with me man im not sure aboutt hese hoshino wheels, there cool, rare, i love the look, but there 14's, and trying to lower a car on 14's then go out and drift on 15's like i do, is highly annoying, not to mention my tire choices, and my contact patch im probally going to throw them up for sale, and get some 16x8 i want a good =10 offset or something here are the pictures |
#23 |
![]() Join Date: Jun 2004
Looks good.
if you are keeping the Sohc in there I would def find a ca20e 87 or 88 car and take the rear end out for a irs, drive shaft and trans. Swap the KA bellhousing onto the CA20e trans, fix your weird driveshaft and shifter placement. plus that short ca20 trans has super tight gearing, which will help drifting with such little power.
[email protected] |
#25 | |
im pulling a ca20e from a s12 and doing a dohc ka swap at my house so id have a chance there to get it.. but that is alot of work my plans, could possibly be to get a ca20 car, because i miss IRS, sra is kinda annoying but fun i got a new job at autozone, i want a ca18det, or sr |
#28 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
Damn! That's awesome, dude. I've seen the pictures from Drift Nirvana events, but I never knew there was this much custom work. It's good to see another 18 year old doing good. I hope to see you at some events this year.
#29 |
![]() Join Date: Aug 2003
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
wow.. Thats thing is a beast. hooray for scabin shit together..
I lol at the scavenging from the toolbox for the switch panel...
89 240sx hatch #933-the hot rod 91 240sx coupe #131,603-the daily |
| build, drft, s12 |
