Old 05-29-2012, 06:59 PM   #1
Nick410
Nick410 is an unknown quantity at this point
Fog lights don't work
I recently bought new fog light bulbs and housings. I plugged them in but they won't turn on. I have a 1995 240sx if that helps.
Thanks
Nick410 is offline   Reply With Quote
Old 05-29-2012, 07:07 PM   #2
DJZ
DJZ's Avatar
DJZ is an unknown quantity at this point
they probably gave you the wrong bulbs, I dont remember the part # off hand but you can tell by looking at the bottom of the bulb if it has one contact point deal thing its wrong if it was two its right... thats most certainly the problem same thing happend to me
DJZ is offline   Reply With Quote
Old 05-30-2012, 01:01 AM   #3
Nick410
Well I went to the store and they looked up what bulbs go with my car. They fit and everything, it's just when I plug in the harness they don't work when I turn the lights on. I have HID's and from what it looks like they are attached to the ballast (i'm not sure), when I took the original ones off the car, the passenger side worked only, not the driver side. So I replaced both of them and now both don't work.
Old 05-30-2012, 01:15 AM   #4
jesse_s13
jesse_s13's Avatar
jesse_s13 is an unknown quantity at this point
Do you have the foglight relay?
jesse_s13 is offline   Reply With Quote
Old 05-30-2012, 01:18 AM   #5
Nick410
idk, where's that located?
Old 05-30-2012, 11:37 AM   #6
xninjaxkirbyx
xninjaxkirbyx is an unknown quantity at this point
sorry i dont mean to tread jack but i have a 97 kouki with jdm front end. just wondering what size foglight bulbs it uses and if it is different size than the usdm?
xninjaxkirbyx is offline   Reply With Quote
Old 05-31-2012, 11:33 PM   #7
Nick410
Still doesn't work, checked everything. how do you take out the fog light relay?
